Air ride installed...
Old Dec 27, 2012 | 07:58 PM
  #741
coolerman69's Avatar
coolerman69
Originally Posted by BenBoosted
Something is going to have to move. I have a fuse box on the drivers side and the PCM/Dynojet PC3 on the other side.
Just did an 03 RK tonite and I put it above the fusebox on the left side
Old Dec 28, 2012 | 06:48 AM
  #742
str8fan3's Avatar
str8fan3
Originally Posted by Paul's Road Glide
What does this power lock actually look like?
What is the amp rating for that switch...do u run a relay with it?
Old Dec 28, 2012 | 08:46 AM
  #743
coolerman69
I don't know what the amp rating is but they have been used numerous times with no relay and no problems
Old Dec 28, 2012 | 09:27 AM
  #744
DuraGlide's Avatar
DuraGlide
I run a relay on the compressor side of that switch but not on the dump valve side. Compressor operates longer time and pulls more amps so I figured it was cheap insurance. Switch will probably last forever working thru a relay.
Old Jan 10, 2013 | 08:48 PM
  #745
BenBoosted's Avatar
BenBoosted
Alright all of my stuff is in. I started on it tonight. No way is the compressor going to fit on the left side, my cruise control box is there. So it looks like I'll need to install it under the battery box.
I started taking it apart so that I can get the battery box out...can somebody confirm that I'll need to pull the rear wheel off to get what appears to be the last screw going through the fender to the bottom middle of the battery box?
Old Jan 10, 2013 | 11:12 PM
  #746
twistedcherokee's Avatar
twistedcherokee
I got it off with out pulling the wheel. Did put it up in the air so the wheel is dropped as far as it would go. I think I got it from the belt side (it has been a few months). It was tight but doable.
Toby
Old Jan 11, 2013 | 08:25 AM
  #747
BenBoosted's Avatar
BenBoosted
Thanks for the tip!
Old Jan 13, 2013 | 10:18 AM
  #748
BenBoosted's Avatar
BenBoosted
So I just finished my install. Below is a video I just made and put on youtube.
Aired up all the way I do have an interference, but I'm not worried about it since I'll never ride completely aired up. Right now I'm checking for leaks. I've found one so far with soapy water, but am still loosing about 8# of air/hour. I haven't found any others yet, but I'm still working on it. Overall I'm happy with how it came out. Putting the ECM below the battery box was MUCH easier than trying to get the pump below there.
Thanks for everyone that contributed to this thread. I was able to order all of my parts before hand instead of starting/stopping for a parts run a few times throughout the project. The hardest part of the entire ordeal was getting the battery box out in order to mount the ECM below it. Other than that it was a snap.
Here's a video I just made showing the setup.
http://www.youtube.com/watch?v=Sa6zj...ature=youtu.be
Old Jan 13, 2013 | 11:43 AM
  #749
coolerman69
WOW that thing dumps fast! I leave my batt boxes in place. Made me a hole template and now its no trouble
Old Jan 13, 2013 | 11:53 AM
  #750
BenBoosted's Avatar
BenBoosted
Yeah I've got everything but the shocks on the larger 1/4" tubing then Y'ing into 1/8" right before the shocks. I've got a muffler for the dump valve on order and will install that to slow it down after it gets here.
I also think I have all of my leaks fixed. It's been holding 80# steady for over an hour now without loosing a single pound. I did a short test ride and so far so good.
