Air ride installed...
Old Feb 17, 2014 | 11:53 AM
  #851
Joe What's Avatar
Joe What
Installed on a 2004 road king using the Monroe shocks. If for whatever reason I lose air and can't air bike up the rear tire rubs on fender... Anyone else encounter this if so what is the fix other than the obvious. Thanks.
I'm also losing air... Bad shocks? I've hard lined just about every connection..
Old Feb 17, 2014 | 12:20 PM
  #852
hotline1's Avatar
hotline1
You need to use soapy water to check all air line connections when I installed mine had two leaks. are you running stock tire
Old Feb 17, 2014 | 12:30 PM
  #853
hotline1's Avatar
hotline1
For you guys having trouble with ride height I installed a remote switch on mine so I can stand behind it to set height from the back I go about 240 and best ride comes at about 1 inch above the mufflers. While your riding heat from the mufflers will cause air to increase if on long ride you may need to let air off during your trip
Old Feb 17, 2014 | 12:40 PM
  #854
Joe What's Avatar
Joe What
I checked all connections no leaks. I am running stock tire.
Old Feb 17, 2014 | 07:13 PM
  #855
hotline1's Avatar
hotline1
Air has to be going somewhere could be a bad shock but I would bet bad connection also could be your valve
Old Feb 17, 2014 | 08:51 PM
  #856
wolf1340's Avatar
wolf1340
Does anyone have a back up to manually fill the shocks? I remember reading about it but can't find it. I'd like to have a back up in case compressor or relay fails. I allready had a relay fail and it wasn't a fun ride back home. Ideally I'd like something built in. But worse case I'll get shrader valves with push connection with a short piece of hose.
Old Feb 17, 2014 | 11:25 PM
  #857
coolerman69's Avatar
coolerman69
Shocks come with a shrader valve t
Old Feb 20, 2014 | 06:26 PM
  #858
2006shark's Avatar
2006shark
So you don't use the sleeve from the energy bushing kit right. You just use the bushings and washers on each side of the shock.
Old Feb 21, 2014 | 06:24 AM
  #859
coolerman69
I have never used energy bushings in any of my installs. I simply drill out theop hole to 1/2". I think this is why I've never had shock trouble.
Old Mar 24, 2014 | 10:17 AM
  #860
DocO's Avatar
DocO
Default 2014 FLHTK installed
Finally got around to installing an air ride on my 2014 Ultra. Does exactly what I want it to do, but there's only one drawback. Because of the new design of the saddle bag mounts, you can see the compressor/bracket from the rear end of the bike. I guess I need to get a set of filler panels now. That was a cost I wasn't expecting...
