Air ride installed...
I come here with a Dyna that I have heavily modified to a touring Dyna bagger and now want to put an air ride on it. There are some other Dyna owners that have done this, but the time that this thread has been running gives me something I can't getwith the Dyna section, lots and lots of feedback. Reading this it seems that there are next to no issues with the Monroe shocks and a few problems with the Gabriels. I like the Gabs because of the inclosed bag and think I will take my chances with it before going to the exposed bag Monroe. All the links to different air fitting and parts used to build everyones systems has been very helpful in putting together my parts list.
Now my primary reason for coming to this thread was to see where everyone is mounting the compressor. I quickly discovered that the panel under the seat is the (almost) ideal location for many of you, but not everyone. With a few seaches of my own I came across the location I believe I will be using, then a day or so later I read about a members using this same location but without showing the pics. I found a company that mounts in the same location, but still wants to much for the system.
Here are some pics of my Dyna Street Bob, the compressor location (to answer the calling many have asked for about another location to mount it) and the link to the company that showed the mounting location.
I want to do this setup on my Bob and hopefully on the New 2015 Limited Low if I can work one into my budget in the spring.
Again, THANKS FOR ALL THE HELP!!!!!
My ride!
My future ride! (I'm only 5"6", and I can flatfoot both feet)
The link and their compressor mount setup.
http://www.cylentcycles.com/air-ride...FbTm7Aod_UsATA
I hope that helps.
Thank you.
FrankEGD
http://www.airedup.com/webstore/smal...g-adapter.html
These go on the Monroe shocks...
Thank you
FrankEGD
