Air ride installed...
Old Mar 17, 2017 | 09:31 AM
  #1031
HotRod9mm's Avatar
HotRod9mm
Originally Posted by santajim
Where did you buy those bushings
You can get them at a number of auto parts stores:
O'Reilly's
AutoZone
Amazon Amazon
Or FACTORY direct
Old Mar 30, 2017 | 10:31 AM
  #1032
Ghost rider1's Avatar
Ghost rider1
Default Anyon
Anyone have any other issues with this I know this is an old thread but like to know if there's any bugs that need to be worked out also where can I get a air tank to make it fill faster or do I even need one
Old Mar 30, 2017 | 02:18 PM
  #1033
sponger's Avatar
sponger
Issues like what? And hoe fast do u want to lift? Like a hydro car?
Old Mar 30, 2017 | 07:13 PM
  #1034
Ghost rider1
issues like leaks, pump failing , use the metal disconnects apposed to the plastic, what kind of solenoid I see 2 way 3way. Are the kits off ebay any good. I research site that have the air tanks called instant ups
Old Mar 30, 2017 | 07:47 PM
  #1035
Pitbull2411's Avatar
Pitbull2411
Do yourself a favor and use DOT lines and fittings to minimize leaks. I also added a tank for instant up as it was worth it to me to air up in one second vs. 7-10.
Old Mar 31, 2017 | 05:56 AM
  #1036
sponger's Avatar
sponger
I dont care about airing up quick, but i def would like to dump air quicker. Looks cooler at bike nights.
Old Mar 31, 2017 | 07:50 AM
  #1037
Ghost rider1
I dont care about airing up quick, but i def would like quicker. Looks cooler at bike nights.
Right and thanks for the input
these kits on amazon I guess are legit, is there a way to prevent a bottom out if air is lost , and use a 2 way solenoid, oh by the way it's for a 2012 SG
Old Mar 31, 2017 | 07:58 PM
  #1038
sponger's Avatar
sponger
Not that ive seen, as far as bottoming out. Thats where my air gauge in my dash comes in handy
Old May 21, 2017 | 06:42 AM
  #1039
CookUltraClassic's Avatar
CookUltraClassic
Default Guide me through it
Originally Posted by 999 Customs
First I started with the compressor, I went with the Arnott 092c (120 psi) They average about $60.
My buddy had the solenoid still in plastic, he sold me that for $20
Air line.. (1/4" x 15') $5 (1/8 x 20') Included with the shocks.
Hand full of quick release fittings in 1/4 and 1/8 -$10
I used : (3) 1/8-1/4 pipe (2 for the shocks, and 1 for the release)
(1) 1/4-1/4 pipe (for the air supply in from the compressor)
And the shocks them selves... Monroe (MA785) for 60's-80's Corvette. $74.99 (Pepboys or O'Reiley) Here's the tricky part.. The lower mounts have to be cut and have an insert pressed into them to make them fit correctly on the bolt. Also... The upper bushings have to be removed and replaced with a proper fitting set, we used urethane, and stainless inserts, sure it's the more expensive way to go, but it is my bike...
TOTAL...
$83 Shocks (after tax)
$20 Shock mods (bushings and inserts)
$80 Compressor (tax & shipping)
$20 Solenoid
$5 Air lines
$10 Fittings
$118
So essentially $220 but that's because I got my buddies prices on everything (lines, fittings, the solenoids are usually like $80, and free labor)
He is running a deal on them, $499 INSTALLED.. Started as a joke, but if someone in So Cal. wanted it, he would do it for you guys..
Could you guide me through the process?
I have a 2005 Ultra Classic and I want to do this. Is there a way I can give my personal email and have you guide me through this build and install?
Old May 21, 2017 | 08:08 AM
  #1040
hellonewman's Avatar
hellonewman
I didn't read all 104 pages but I read a lot of them! Didn't see mention of people running the Premium ride hand adjustable shocks from HD. Do they suck? Are they expensive or both? I saw mention of screamin eagle shocks on a RK in this thread and they had great reviews.
