Air ride installed...
Old May 23, 2014 | 07:15 PM
  #911
Brettfullthrottle's Avatar
Brettfullthrottle
Originally Posted by twistedcherokee
Gabriels #49304. I have run it without the compressor. I had a dump valve that had an odd size line that I could not get sealed, so I disconnected the compressor until I got the switch that I wanted & got rid of the dump valve.
Toby
Thanks! Just ordered them!
Old May 23, 2014 | 07:35 PM
  #912
HTNHARD's Avatar
HTNHARD
The only dump valve solenoid to buy is the one from Grainger. I've had others that were nothing but junk. Also buy the push to connect fittings from airedup.com Saves allot of headaches.
Old May 24, 2014 | 10:22 AM
  #913
snailhouse_projects's Avatar
snailhouse_projects
This is true the solenoid is great and it's loud which is one thing that I like and the fittings are leak free! The only leak I had was on the check valve on the compressor, it came like that from viair. Half a turn and it was fixed! Thanks to HTNHARD I was able to get this whole thing installed in under two hours.... Awesome set up and my wife like the ride way better than the stock set up!
Barnabie
Old May 24, 2014 | 10:26 AM
  #914
The Q's Avatar
The Q
Barnabie
Y'all got a part number for the Grainger solenoid of choose???
Old May 24, 2014 | 11:31 AM
  #915
snailhouse_projects
I will get it for you when I get home bud!
Old May 25, 2014 | 12:57 AM
  #916
twistedcherokee's Avatar
twistedcherokee
I like this because the lowering is mechanical instead of electric & when you raise it, it runs the pump.
http://www.sdtrucksprings.com/index....oducts_id=9888
I made a box to hold it & put it just above the starter since I am running true duals.
Toby
Old May 25, 2014 | 10:23 PM
  #917
pappleng's Avatar
pappleng
Stage IV
a lot to read thru, i have a 92 FLHTC I'm getting ready to start this project on. Also I've been kicking around installing the 93 and up bags. Any suggestions for my model year?
Old May 26, 2014 | 05:26 PM
  #918
snailhouse_projects
This is the valve the part number is 6JJ52. Sorry it took so long!
Old Jun 1, 2014 | 08:46 AM
  #919
teeboz's Avatar
teeboz
Since adding my 26 wheel the bike now drops too low and fender now rests on the tire. Is there anyway to prevent the air ride from dropping this low? Would hate to be riding and lose air and contact the fender.
Old Jun 1, 2014 | 11:09 AM
  #920
twistedcherokee
You may have to install different shocks that don't collapse so far. My 140-90-16 Dunlop does that also, but my Kenda Challenger & Metzler ME880 did not. Thinking of going to a 150-80-16 on mine. But since you have changed your wheel size & that is the look you want, if you look at the frame & the swing arm, you might be able to bolt or weld something in to act as a bump stop. Good luck & let us know what you find.
Toby
