Air ride installed...
But I used this:
I tried to use the least amount of push-to-connect connections, rather then threaded connections, which IMO are easier to seal. All other components can be found by searching for (i.e.) push-to-connect 1/4" OD 1//8" NPT, if you need a 1/8"NPT to 1/4" hose p2c for the compressor or valve to hose connection.
I do not completely agree with some comments about the 1/4" line being more stiff, it works just fine for me.
Best way to go is getting the compressor, valve, shocks and what ever else you want to use. Then check Amazon for SMC fittings, or Airedup.com. I found Amazon to be a better source, and if you order all parts together, you most likely get it shipped free....
BTW, I put about 3000mls on the bike since installing the air suspension, and had zero issues.
I hope that helps.
Thank you
FrankEGD
But I used this:
To hooked up left and right shock, gauge, Schrader valve and line to fairing with compressor and dump valve.
I hope that helps.
Thank you
FrankEGD
I bought these, and they are the right size, but they stick out way too far. On the right side your either gonna hit the saddlebag, or the brake caliper on full drop. I really want brass fittings for this, but I'm rethinking about just using the 1/8" kit that came with the shocks.
Thank you
FrankEGD
