Air ride installed...
Old Jan 9, 2015 | 05:13 PM
  #961
meangreen02's Avatar
meangreen02
Just curious why would you go with a system like that instead of custom building your own?
Old Jan 10, 2015 | 08:29 AM
  #962
Punjabi Rider's Avatar
Punjabi Rider
Don't have a welder neither I know how to, heard top mount cracking and 1/4" fittings are better and top it of with zero air ride-able made me go in that direction. It's for my wife want to have minimum difficulties on the road in case of compressor failure . Finished it yesterday tried out with zero air at 75 mph on rough road wasn't too bad.
Old Jan 10, 2015 | 09:13 AM
  #963
meangreen02
Fair enough, for what it is worth there are several hundred installs on here with zero failure with the top shock mount (I am thinking there was a bad batch or improper install) I am running the monroes and can ride all day with no air but that would just be silly. I hope the wife likes it I love mine and constantly get complements on the look of the bike. (this was written for the benefit of others so please do not take offense!)
Old Jan 20, 2015 | 02:53 PM
  #964
Punjabi Rider
Just finished a 1300 miles ride and the AIR RIDE is coming off wife is not happy with comfort and limits on lean angle when lowered, even in gas station parking lot bike scrapes really bad. I will probably end up selling the whole set up.
Old Jan 20, 2015 | 06:50 PM
  #965
twistedcherokee's Avatar
twistedcherokee
That is when you raise it up. If you were to just lower it, no matter what system you use, it will do the same thing. The nice thing is you can lower it to get on or off or just cruising from bar to bar & if you come across a dip, you can raise it to clear. That is the purpose of the system. Good luck
Toby
Old Jan 21, 2015 | 12:38 AM
  #966
meangreen02
I think you should do exactly that! Again I am not sure what system or how you installed but the system I installed has six inches of adjustment, yes I can even raise from stock if I wanted. If it scrapes you don't have enough air in the system. It is laughable to think that the stock 2007 suspension is more comfortable. I had 2010 street glide air shocks on my road king, and this system is without question way better, and I ride two up all the time.
Old Jan 21, 2015 | 02:08 AM
  #967
06SGWA's Avatar
06SGWA
These aren't really meant for riding around with no air in them. Of course the bike will drag and be uncomfortable as hell with no air in them. Instead of putting the stock shocks back in, use the current setup to raise the bike to stock height.
Old Jan 26, 2015 | 09:08 AM
  #968
Kwesty's Avatar
Kwesty
Can someone post me diagram of the setup for the DIY install and what size hose you used in each section.
Old Jan 26, 2015 | 12:06 PM
  #969
06SGWA's Avatar
06SGWA
https://images.search.yahoo.com/yhs/...hspart=mozilla
Old Jan 31, 2015 | 03:13 PM
  #970
Kwesty's Avatar
Kwesty
Can someone help me out I am having issues getting my solenoid to purge and im not sure if I am doing something wrong.
This is my solenoid
http://www.airedup.com/webstore/1-4-...oid-valve.html
Says it doesn't matter which terminal is which on hook up but I can get air through it just not able to purge. Any help is appreciated because im about to pull out what little hair I have.
I am using a 2 momentary I got from radio shack and that switch may be part of my problem.
