modified seat question
Old Dec 12, 2010 | 01:26 PM
James K's Avatar
James K
Default modified seat question
Have any of you that enjoy building/modifing parts on your bike made a two up seat in to a solo seat?
What kinda bracket did you make to retain the seat?
Did you just re-use the stock seat covering or stitch up a whole new one?
I have a spare SG seat and was just pondering the idea.
I know there are those out there that will say just buy a solo seat, but hell anybody can do that
Old Dec 12, 2010 | 01:35 PM
mkguitar's Avatar
mkguitar
H-D uses a T shaped bracket for the rear solo seat mount, so you could do that, it comes off of the 2 fender bolts and extends rearward.
Um, I bought a brawler seat from another forum member
MK
Old Dec 12, 2010 | 03:09 PM
glide2005's Avatar
glide2005
Why not modify your on seat, I did.I took my old stock seat from 05 and a saws all and wa la, a solo seat was born. Mounted it on the frame from a air ride seat bracket from a cop seat and had a very comfy solo.
Old Dec 12, 2010 | 05:28 PM
James K's Avatar
James K
exactly my thoughts. Do you have pics of what you did?
Old Dec 12, 2010 | 07:38 PM
kruzin's Avatar
kruzin
I cut mine down.
Reshaped the seat, used the same pan and covering. Just cut it to fit.
Old Dec 12, 2010 | 08:08 PM
wardawg1's Avatar
wardawg1
Here is 3 pics I included of my modified solo seat. Originally was a LaRosa Design bobber seat that we completely tore apart and just used the pan. The seat was built up with 2 different types of foam and gel was inserted into it. All hand done time consuming upholstery work. A new t-brace was constructed to secure the seat to the frame and grinded down so it would not hit the fiberglass pan that was made to cover up wiring. I did not like the height of springs or mini shocks so we found toilet tank parts that have stumps in them that allow the seat not to bottom out. This seat is 10 times more comfortable than the stock and I love the profile on the bike.
Old Dec 12, 2010 | 08:11 PM
James K's Avatar
James K
Originally Posted by kruzin
I cut mine down.
Do you have a pic of how you fastened the back of the seat to the bike?
Did you use the detachable solo tour pac mount?
Old Dec 12, 2010 | 08:32 PM
wardawg1's Avatar
wardawg1
Since I made mine a bobber I didn't need to fasten it down but the fiberglass pan that goes under the seat to cover wiring and stuff now uses the original stock hole in the fender and a thumb post screw holds it down instead of stock screw that requires a screwdriver.
If your just modifying an exiting seat then I would try to cut it down to use one of the holes already drilled in the fender. Mine has 3 holes predrilled.
Old Dec 14, 2010 | 09:07 PM
kruzin's Avatar
kruzin
I am out traveling this week but can attach a picture when I get home. Basically I made an H frame from aluminum straps pop riveted to the seat pan, they then attach to the solo seat mounts on the fender.
And yes the tour pack is detachable. I can unplug the harness, remove the tour pack and install a Mustang rear seat that I had left over for a passenger if I want. The rider seat is held on with the mustang attaching hardware nuts so the mustang seat fits right up to it. Slap on the back rest and we are off!
Sash302
Jul 13, 2020 02:27 PM
lightning95
Mar 25, 2017 08:32 PM
Sudzz
Dec 17, 2012 08:36 PM
Cheeze
May 25, 2009 04:52 PM
chrome-dome-dave
Feb 2, 2009 07:48 AM
