Best tune for my buck
Old Feb 11, 2011 | 12:01 AM
04ROAD's Avatar
04ROAD
Question Best tune for my buck
Got a stock 97 ultra with rush slip ons...whats the best bang for my buck when it comes to tuning? I dont want to touch the internals of the bike just for reliablitity reason of my own. I eventually want to put a nice A/C on it. What do you guys recommend? Thanks
Old Feb 11, 2011 | 12:33 PM
ucommbxny's Avatar
ucommbxny
if you put a high flow A/C you will have to tune. If you are going to a local shop talk to them about the tuner, some shops prefer to use a certain one. all i can tell you is what a friend of mine experience has been, for years he had pc iii usb, last year he switched to the sert. he says that he gets better mpg and power from the sert. everyone will have a different opinion.
Old Feb 11, 2011 | 01:50 PM
1sweetglide08's Avatar
1sweetglide08
There are many to choose from, I had a PC-V and it was good. It was plug and play with good results. Then after I put in a set of SE 255 cams I went with a TTS Mastertuner...only because I didn't want any extra equipment attached to my bike.
Old Feb 11, 2011 | 02:01 PM
carpetride's Avatar
carpetride
if fuel injected I'd say the best bang for your buck is a V&H fuel pak from some discounter like eastern performance. But put the a/c on it for best results.
Old Feb 11, 2011 | 04:48 PM
04ROAD's Avatar
04ROAD
my bike is fuel injected...ill check out the V an H fuel pak
Old Feb 11, 2011 | 04:52 PM
Firetender's Avatar
Firetender
I went with the one that was HD's first choice: PCIIIusb from Dynojet. Negotiations could not be reached for both parties' satisfaction, so HD went elsewhere and now sell their SERT-type tuning line. My race tuner dropped SERT tuning for various reasons as well relating to the dynamometer tuning procedure for that as well so there I was...haven't found anything better yet! Your limited modifications tell me a "canned" map would do nicely as well to save you the cost of an individual-cylinder Dynojet tune.
Old Feb 11, 2011 | 04:55 PM
04ROAD's Avatar
04ROAD
i checked out vance and hines and they didnt have anything for my year...
Old Feb 11, 2011 | 05:55 PM
mkguitar's Avatar
mkguitar
Alot of the above responses are for newer model bikes, with the twin cam motor.
your evo has the magnetti-marelli injection- which I know nothing about- my evos are all carbed.
With slip ons and stock restrictive air cleaner, you are probably ok. Once you allow more air in the intake tract then you do have to add more fuel to match.
nightrider.com might be a good place to start reading up. - If you have a california emissions bike you may really, really benefit from a simple cam swap.
mild cam swaps can add moderate power and not compromise performance.
mike
bbrooks1963
Sep 16, 2013 09:37 AM
Mimo951
Jun 17, 2012 10:30 PM
jisananimal
Oct 20, 2011 12:20 PM
Cav Cop
Nov 12, 2009 09:10 AM
confused
Aug 24, 2009 04:53 PM
