Need help removing outer faring 03 ELG Classic
Old Feb 14, 2011 | 09:34 PM
garcon's Avatar
garcon
Default Need help removing outer faring 03 ELG Classic
Guys, feel like a fool for asking, but I can't seem to find all the screw to take the outer faring off my 03 Electra glide Classic. I have on 02 workshop manual and it just seems to mention screws below the lower side glove boxes...mind is not the ultra, has no lower glove boxes. I thougth I had removed all screws..three on the windshield, and two lower ones on the side. Also took off the chrome rim around the front headlight but the faring still seems to be hung up somewhere on the bottom. Am I missing something? This should be a simple task, but my eyes and age are getting older and I know I must be missing something. Can anyone tell or show me what screws I am missing? I have to take of the outer faring becuse I have a Dakota digital antennae mounted inside and I believe I have some loose wires....sometimes the radio signal get static or dissappears if I shake or give the faring a hard tap. Also, where inside the faring would be the best placement to stick the antennae, or doesn't it really matter? Thanks in advance for any help.
Old Feb 14, 2011 | 09:49 PM
dawg's Avatar
dawg
https://www.hdforums.com/forum/381727-post1.html
Old Feb 14, 2011 | 09:50 PM
dawg's Avatar
dawg
There are 7 screws total. 3 on the windshield, 2 under the speakers and 2 down by the forks behind the fairing skirt
Old Feb 14, 2011 | 09:53 PM
Fast Aire's Avatar
Fast Aire
Former Sponsor
7 screws total hold the outter fairing on....
3 outside where the windshield is
2 in the inner fairing, outside the speakers
2 down below , right inside the fork tubes, between the upper & lower triple tree
Once all 7 are out, pull the outer fairing forward, disconnect the light & it lifts off
edit: looks like dawg & me answered at the same time
Old Feb 15, 2011 | 04:56 AM
katobird's Avatar
katobird
I usually take the light bar loose...
Seems to give me more room when removing..
The rubber seal below the headlight may be sticking too
Old Feb 15, 2011 | 05:24 AM
mainshaft's Avatar
mainshaft
I throw 2 wool socks over the running lights to help keep the scratches away.
Old Feb 15, 2011 | 06:05 AM
Chaffeekid's Avatar
Chaffeekid
I have to turn the front wheel sharply to the right then take out the lower screw down by the forks, then sharply left to remove the other one. Those are the ones giving you problems. Don't pry on the faring until you have taken all seven screws out or you could break off one of the standards, don't ask me how I know. Then you have to work with fiber glass to put it back on.
Ride Safe, Road Hazards are everywhere.
Old Feb 15, 2011 | 06:29 AM
garcon's Avatar
garcon
Thanks for the help...I had the bike on a front wheel chock and I was trying to look for the bottom two screws without being able to turn the bars.....I will give it another shot today....Thanks
Old Feb 15, 2011 | 06:40 AM
Wally's Avatar
Wally
Cover the fender and gas tank with towels. A dropped tool will take a nasty chip out of the paint.
HarleyorNuttn
EVO
Apr 22, 2019 09:03 PM
Xarmy2005
Audio Systems
Feb 25, 2018 06:43 AM
hipshot
Jun 28, 2010 07:00 AM
Roadman56
Jul 7, 2009 05:05 PM
lp
Aug 11, 2006 10:33 AM
