Security System Fob
Old Feb 23, 2011 | 02:02 PM
pargenz's Avatar
pargenz
I just treat the fob like a key and take it with me whenever I'm using the bike, otherwise it's in the house with the other keys.
Old Feb 24, 2011 | 05:23 AM
glook1's Avatar
glook1
I bought my scoot used with no owners manual. Any suggestions how I would obtain my PIN?
Old Feb 24, 2011 | 05:32 AM
geezer glide 56's Avatar
geezer glide 56
What year is your bike?
Old Feb 24, 2011 | 06:35 AM
glook1's Avatar
glook1
09 Street Glide
Old Feb 24, 2011 | 06:46 AM
jeffreydsilver's Avatar
jeffreydsilver
Default with the key
I am fairly new to owning the newer bikes, never had one with a security system. Everytime I am in my shop and want to start my scoot the alarm fob is on the bar in the house. What do the rest of y'all do with yours? Put them in the saddle bags? I know this type of question brings out the smart a$$ in people so take your best shot. I'd also like to hear from the more serious crowd also.
Keep it with the key (on you) and lock the bike whenever getting off of it! Anything less defeats the purpose of having it!!
Old Feb 24, 2011 | 06:53 AM
bikehe's Avatar
bikehe
I keep my FOB in a zipped pocket inside my jacket. Jacket never stays with the bike unless I'm riding. I also bought the kuryakyn push button release for the fuel tank that way I never have to worry about taking the fob and key out of my jacket to unlock the tank. Only started doing this after I nearly lost the fob one day. Works well for me
Old Feb 24, 2011 | 07:23 AM
geezer glide 56
09 Street Glide
With the fob in range (I usually put it on the seat while checking the pin on trade ins) Turn the ignition switch on and off 3 times and turn the switch to the on position...Press the left turn signal button twice...The signals will flash about 3 or four times...Press the right turn signal once...The pin should show up in the odometer...Some times it won't do it the first time you go through this sequence...If it doesn't repeat the sequence until you see the pin in the odometer...I hope this helps.
Old Feb 24, 2011 | 07:45 AM
Sandcrab's Avatar
Sandcrab
Default Owner's manual
You need to have the FOB on your person to get the security code. According to book, follow these instructions:
Turn ignition switch on/off/on/off/on
Press left turn signal switch 3 times
Press right turn signal once and release
The turn signals will flash 3 times, and the pin will appear in odometer, with the 1st digit flashing. Write down the 5 numbers so you know what they are.
Old Feb 24, 2011 | 08:19 AM
FDHOG's Avatar
FDHOG
I treat my bike keys like my car keys. When I'm on the bike I have my keys. When I'm home, they're on the wall. Can't start either without the keys. Where's the problem?
Just make sure the FOB is far enough away from the bike that you can't start it.
Old Feb 24, 2011 | 08:32 AM
Texas Fat Boy's Avatar
Texas Fat Boy
Actually Tex I owned my 97 Fatboy for 10 years and had to find the keys to sell it. I never locked the ignition at home or at rallys. I do appreciate all of the feed back though. Thanks
If that's what you're use to, then leave it in the saddlebag. I like my security system.
I leave a key in the saddlebag and carry the fob. That way if I'm out, I have a key to lock stuff up, but it ain't a pain in my pocket. I keep the fob on a carabiner,
Malleck
Oct 17, 2022 07:51 PM
Redlegvzv
Oct 16, 2020 03:33 PM
Nate8604
Mar 14, 2018 10:09 PM
sedouglas
Jan 1, 2012 02:31 PM
DannyZ71
May 15, 2008 10:05 PM
