Super Easy Shift Linkage Mod
Old Jul 12, 2018 | 08:53 PM
  #171
F150HD's Avatar
F150HD
Originally Posted by Mertoid
There are tons of shift linkages on ebay. Over 2 years ago I bought a $25 unit with heim joints, polished Harley logo. Still works just fine. No need to buy joints and build your own unless that's what you're into.
Just a couple examples...
I was looking at those myself....but with 2 bikes, bought the Heims online then hit the hardware store.
BUT, all said and done, prob much, much easier to buy one of them in a 'kit' and not waste 3 hours running around town buying hardware (as I had to).
Old Jul 12, 2018 | 09:52 PM
  #172
Mertoid's Avatar
Mertoid
I would've done the same thing if they weren't available premade and so inexpensive. I'd have even made the aluminum part too, I own a tool and die shop, but for $25? Why reinvent the wheel?
As to the loose transmission shift lever, mine was loose a few years in. No amount of tightening the allen bolt would fix it. So I took the lever off and profile milled around the outside of the splined end to thin it and allow it to flex more and grip the splines. Been ok for years now.
Old Jul 12, 2018 | 10:33 PM
  #173
harkon's Avatar
harkon
If you want the shifter rod chrome, go to the hardware store and get a chrome toilet feed/supply pipe. Cut to just under the length between the jam nuts. Take one end apart and slide it over the shifter rod. I used a couple of dabs of RTV, one at each end to keep it from rattling about. It seems these pipes are chrome over copper. I've had mine like this for the second summer now and it still looks great. Not bad for $3.00.
Old Jul 12, 2018 | 11:15 PM
  #174
F150HD's Avatar
F150HD
duplicate post. deleted
Old Jul 12, 2018 | 11:24 PM
  #175
Veekness's Avatar
Veekness
Originally Posted by F150HD
yes, have seen but it was $$$ so skipped it! maybe down the road, thanks
My take on it as well.
Old Jul 13, 2018 | 07:17 AM
  #176
skratch's Avatar
skratch
well, when i first posted this thread in 2011, i can tell you that there wasn't the plethora of shift linkages available then as they are now. so the $8 i had invested in parts represented a significant savings over what i would have had to spend at hd/jp/etc. and to be totally honest, i'm a cheap bastard, even $8 vs $25 would have me thinking....
Old Aug 7, 2018 | 10:52 PM
  #177
Jpiencak1's Avatar
Jpiencak1
3rd Gear
So this thread is pretty old but im looking to do a direct linkage on my 78 shovel and get rid of the silly cam system. Anyone have any info or thread they can point me to? Thanks!
Old Jan 23, 2019 | 05:36 AM
  #178
Lowriderbigboy's Avatar
Lowriderbigboy
Newbie here! Can anyone tell me how to measure for an aftermarket shift linkage?
ive found with this 2018 breakout that due to the new design of the bike, most vendors or manufacturers either don’t list parts for it that are interchangeable or don’t know which ones are yet!
Ive found 5-6 parts so far that are either universal or interchangeable and even Harley told me it won’t work. Yetbits on and works great!!
any advice would be appreciated!
Old Jan 24, 2019 | 03:58 PM
  #179
Musician's Avatar
Musician
Originally Posted by Leftcoaster
Sorry, but no banana.
Go out and actually look at your shift levers.
If you do you will observe the toe shifter is inboard leaving the **** on the end in a position that can be reached by the toe of a shoe sans any 'pigeon toe' effect.
If you like having only the toe shifter, as many do, cutting of the remainder of the splined shaft will leave the toe lever in the exact same position as a stock bike while allowing you to keep your foot closer to the primary - no 'pigeon toe' effect there whatsoever.
That 'pigeon toe' effect (very slight) only occurs when you leave the heel shifter on or move the toe shifter outboard.
Very obvious to the naked eye. Check it for yourself (use a tape measure and straight edge if necessary).
I removed the heel shifter, put a spacer on the shaft, and remounted the toe shifter to the outside of the shaft I have also moved the boards out by 1 inch,so I don't notice any pigeon toe effect . It lines up, and feels quite natural.
Old Jan 26, 2019 | 10:51 AM
  #180
hbsoldier3's Avatar
hbsoldier3
That has been my experience in the past. Too much time spent running around, back and forth. Shout out to the OP for this thread. This time I just bought the Heim links/Rod ends with the stud.
https://www.speedwaymotors.com/Speed...tud,32258.html
