handlebar swap
Old Oct 14, 2006 | 01:32 PM
dawg's Avatar
dawg
Default handlebar swap
I am having Badx modify my seat soon and he will be moving me down, but not back. I like to sit back enough as it is. I would like the handlebars to come a little closer to me. Any suggestions on bars that I should go with? Any tips on changing them? I have the manual, but is this a straightforward easy job? Will I need all new cables? Thanks.
Old Oct 14, 2006 | 01:48 PM
RonH's Avatar
RonH
Default RE: handlebar swap
I put the Wild1 Chubby BaggerBars on mine and am very happy. They go a bit higher and couple inches closer, depending on how you adjust them - a bit wider than stock too. You need new cables, and it's a big job - but very doable. The thicker bars with internal wires really look sharp!
Old Oct 14, 2006 | 02:27 PM
UGGA's Avatar
UGGA
ORIGINAL: dawg
Here's a link to a rather lengthy thread that I wrote about installing the WO575's on my street glide. Hopefully it might answer some of the questions that you might have.
https://www.hdforums.com/m_321033/tm.htm
Doug
Old Oct 14, 2006 | 03:16 PM
dawg's Avatar
dawg
Hey thanks for the link and the link within your original post. Give's me something to follow...scared the hell out me, but still gives me something to follow
Old Oct 14, 2006 | 03:20 PM
UGGA's Avatar
UGGA
Hey Dawg,
Didn't mean to scare or discourage you. Like the above poster said, the job is very doable. Just take your time and it should come out just fine. Remember, I'm an ok wrench, but not the best. Experienced mechanics could do the job in much less time than I did and with fewer problems. Good luck - the results are well worth it!
Doug
scottylonebull
Oct 29, 2015 10:54 AM
cgramirez1
Feb 15, 2014 02:09 PM
MangoMike
Nov 1, 2009 10:01 AM
wallybally
Dec 1, 2007 08:14 PM
Glider89
Aug 29, 2006 11:59 AM
