Spark plug wire mangement - clips
My bike must've been assembled when they didn't have any clips -- Because my bike had panel-mount cable straps. Had to cut them all just to get the old wires off.
Managed to stuff the new wire in the harness clip under the tank to keep it off the heads and I was just going to strap 'em to the frame under the seat when I figured there must be a better way --- Other than the clips that no dealer in the tri-state area seemed to have.
ITW Fastex # 1903-00-3835 -- It fits the 1/4" holes in the panel under the seat and *perfectly* clamps snugly around the 10mm Screamin' Eagle spark plug wires.
http://www.itw-fastex.com/catalog/in...c/20/p/45?m=no
Easy-release (reusable), no additional tension (unlike the harness clip under the tank which looks like it's going to snap at any second), pop-in simplicity.
Where to find them in small quantities is another story... They're "right down the street" from here, so picking up a few to check out was pretty easy. But in any case, consider the legwork done. These are the *perfect* cable management solution for the SE high-performance wires.
SIDE NOTE: I wouldn't have believed it if I didn't hear it myself, but the engine noise in the radio (mostly AM and a bit on low-gain WB stations) has been significantly reduced after installing these wires.
Duh - Winning.
The bike starts up quicker IMO with the new wires.
The "cleaner" sounding radio I'd imagine is simply better shielding.
I have to admit -- I was just looking for a little "splash of color" on that side. And for twenty bucks, even the possibility of enhanced performance is a bargain with something that says "HD" on it... And as often as I have AM radio on (the best way to get in touch with the local Americana when out of town IMO), it's well worth it.
Harley Part Number: 10177, plug in cable straps
is the replacement part you need. No need to jump through hoops trying to find this ITW fastener.
