Xied
Old May 5, 2011 | 05:47 PM
elauee1's Avatar
elauee1
Default Xied
Do xied work for 2010 touring
Old May 5, 2011 | 06:05 PM
MikeySom's Avatar
MikeySom
They work for me I also cut out the cat and wrapped the pipes from the heads to the Y pipe it cooled down and the bike runs great.
Old May 5, 2011 | 06:20 PM
frankiefire702's Avatar
frankiefire702
They seem to work fine. Im running v&h big shots and a k&n drop-in air filter with them.
Old May 5, 2011 | 06:26 PM
elauee1's Avatar
elauee1
Do they only increase afr for 50% of throttle
Old May 5, 2011 | 06:53 PM
wingfoot's Avatar
wingfoot
The XIED will only work while in closed loop. But what most folks don't tell you is that the stock ECM Map is plenty rich in open loop (from ~3700 RPM to limit)
See attached AFR of factory map.
Old May 5, 2011 | 06:56 PM
wingfoot's Avatar
wingfoot
Old May 5, 2011 | 07:28 PM
elauee1's Avatar
elauee1
Will it accommodate for a high flow a/c and slip on. Bike has factory head pipe with cat
Old May 6, 2011 | 07:47 AM
wingfoot's Avatar
wingfoot
IMO, the XIED will be enough for air and slip-ons. Will XIED be the optimal setup "NO"; will they improve the lean condition "YES".
With the cat in the head pipe your mufflers will not sound like you expect/want.
Old May 6, 2011 | 07:55 AM
jjnoble's Avatar
jjnoble
Yes, they will work for a/c and slipons. I think they are great.
Old May 6, 2011 | 08:33 AM
mkguitar's Avatar
mkguitar
Best bang for the buck, uncomplicated, plug right in. probably run you $125 shipped ( military discount offered too).
I have on my 09 with air cleaner and slip ons. Did exactly what i wanted.
mike
