120R mileage and reliability
Old Apr 13, 2014 | 09:36 PM
  #101
tonymontanna1983's Avatar
tonymontanna1983
Default DIY cost of 120r??
What is the bottom dollar cost of the 120r if I do the work myself?
Old Apr 13, 2014 | 09:51 PM
  #102
bagman1's Avatar
bagman1
I dont think you can come close to building a 120 compared to the cost of the crate 120. Either way theres a lot of accessories to buy
Old Apr 14, 2014 | 02:33 PM
  #103
hd_rolling's Avatar
hd_rolling
You could call renegade hd in Alexandria La, that's who installed mine before i left FT Polk La.?
Old Apr 14, 2014 | 02:54 PM
  #104
fwb35's Avatar
fwb35
A friend had one done at a HD dealer, he said total cost out the door was over $13,000 for his Ultra, but thats the HD dealer doing everything, all he did was drop it off and pick it up.
Old Apr 14, 2014 | 03:01 PM
  #105
XFXDX's Avatar
XFXDX
Originally Posted by grbrown
The reality is there hasn't been much mention of them on HDF of late. Suggests they are all out ridin! Take a look in the Tech Engine section, as there are some good 120R threads in there, but again not recently. An alternative now available is a 124" S&S, which can be had in high and slightly less high CR versions (sort of Sport and Touring versions!).
Yeah, copy that. Guess so... I'd be on the fence between the 120R and the S&S, really like the stock look of the 120R. May be worth it, tho, for the 124". Time will tell...
Thanks.
Old Apr 14, 2014 | 03:27 PM
  #106
Egldr05's Avatar
Egldr05
I would disagree with that. If I could find the damn spreadsheet I made up that helped me decide I would post it. I built my 120” from the ground up using my Timken cases. I did however have some performance parts in my 98” build I was able to sell for what some guys are getting for their used motors. It ended up be enough of a savings to justify the building it as opposed to buying a crate motor. I ended up with what in my opinion is a better/stronger motor. The only thing I regret is my choice of cams. That is going to be rectified in the future. A big factor is whether or not you can do your own work.
SE crank (plugged/welded/balanced)
Timken bearings/HD lefty on the right
SE110 heads worked by Don Dorfman (Dewey's Heads)
HPI 58mm throttle body w/Doherty intake/Zippers Hi-Flow filter
Dragula 2-1
Kury WT26 gear drive cams
R&R cam plate
10.5 comp
1.75 ratio rockers
TMAX AT
Bandit Sportsman clutch
Rick
Old Apr 14, 2014 | 04:55 PM
  #107
RottnRam's Avatar
RottnRam
Found this on another forum. A 120R Needs a Total Rebuild @ 10k
I don't post much and not trying to start a war but, I would opt for S&S 124 before a 120R
http://harleytechtalk.org/htt/index....c,71145.0.html
Old Apr 14, 2014 | 05:00 PM
  #108
lkr0's Avatar
lkr0
I totally agree
Old Apr 14, 2014 | 07:44 PM
  #109
hd_rolling's Avatar
hd_rolling
Had mine installed last summer and already have 12,000 miles on mine trouble free. Not enough real owner having issues with these engines just the "i know a guy" complaints and the one guy posted on that other forum. His didn't even have the billet cam plate or high flow pump which would lead me to think his wasn't a crate 120R. I paid under $9000 for my installed out the door and that was with the Harley tuner because the dealer wouldn't use my power vision.
Seems like the S&S owners come on every 120r thread to bash the harley engines?
More than happy with mine (a true 120R crate owner), not word of mouth from some other guy!
Old Apr 14, 2014 | 07:46 PM
  #110
Egldr05's Avatar
Egldr05
How many posts would you like to see from people who have had problems with S&S motors? There's plenty of them out there.
Rik
