bike chirps while accelerating
Old Nov 7, 2018 | 07:05 PM
  #41
e6fmf's Avatar
e6fmf
Check your belt. Feel for loose teeth. push in each direction, may be broken on one sides and will lay back down looking normal.
Old Nov 8, 2018 | 08:46 AM
  #42
btsom's Avatar
btsom
Surprised no one has mentioned the heat shields on the header pipe. Obviously, they go through lots of heat cycles Expansion and contractions) one after after EVERY engine start. The sound that comes to my mind described a chirp is from dry metal to metal contact, though dry rubber comes close.
Old Nov 8, 2018 | 10:23 AM
  #43
cwsharp's Avatar
cwsharp
Originally Posted by Bearcat1
Yeah, that. Mine chirped and drove me crazy for a while until I figured out it was a lose belt. Tightned it up to proper tension and was good after that.
Yeah... my belt had missing 'teeth' and did that.
Old Nov 13, 2018 | 07:44 AM
  #44
Hecklerboy's Avatar
Hecklerboy
Mine was "chirping" whenever I hit a small bump and sometimes at idle.
Turns out it was the rubber muffler isolation mounts.
Those things wear out quickly and will start chirping.
Luckily they only cost $3 or $4 at the Harley shop. Easy to replace.
Old Nov 13, 2018 | 06:25 PM
  #45
dickey's Avatar
dickey
Betcha gonna find it's the muffler rubber.
Or, a boid caught in the woiks.
Old Nov 13, 2018 | 08:01 PM
  #46
yiride's Avatar
yiride
Had a 09 FLHTC . It had a chirp on accel and decel also . It tokk almost two years to find it. On the bolt on rear frame section check to see if there is a rust streak on the mounting bolts. On mine there was a bit of rust at one of those bolts. I loosened all 6 bolts a bit and re tightened those bolts . The chirp went away.I assume that frame section was a little bit bound up at assembly which was corrected with retightening .
Old Jun 17, 2021 | 06:18 PM
  #47
Spec4's Avatar
Spec4
6th Gear
Hey Rucker was it your belt then? My sportster does that also and I'll check it tomorrow. last year I tightened it up. I don't ride that much(5 miles to/from work in the summer).
Old Jun 18, 2021 | 05:02 AM
  #48
NELS's Avatar
NELS
Mine only lasted a few miles until I closed the saddlebag correctly, Felt stupid!
mupepe
Feb 21, 2015 06:07 PM
EricD10563
Aug 12, 2012 12:28 AM
paud
Jul 27, 2010 08:01 AM
NightTrain4Al
Jun 27, 2010 10:46 AM
SMacDunk
May 7, 2009 05:17 AM
