Which LED Headlights?
Old Jul 26, 2011 | 04:53 PM
dmohr43's Avatar
dmohr43
Default Which LED Headlights?
Hi Guys, I am planning on up-grading to LED headlights and spotlights for my '06 Ultra Classic. What sort of service have you had with them? Which do you prefer, Harley's or Kuryakyn's? Was the money the deciding factor, or does one work better than the other? Thanks
Old Jul 26, 2011 | 05:26 PM
viperbsd's Avatar
viperbsd
Stage III
I went with the Harley led headlight and aux lights. They are very pricy, but they feel very solid and they are worth the $$ in my opinion.
My buddy and I have the same bike but his does not have the led's yet and when we ride at night it is amazing how much more road these light up over the stock headlight.
Old Jul 26, 2011 | 08:14 PM
bmarkowitz's Avatar
bmarkowitz
Def the MOCO LED...They look better,easy to install...Makes your ride look like a Freight Train...
Old Jul 26, 2011 | 08:16 PM
alkrisma's Avatar
alkrisma
I too went with the Harley led and yes, they're worth the $$
Old Jul 26, 2011 | 08:22 PM
fm58's Avatar
fm58
+1 on the Harley Headlight & Lamps.
Old Jul 26, 2011 | 08:31 PM
francodanco's Avatar
francodanco
I too went with the HD headlight, well worth the $$$$$
Old Jul 26, 2011 | 08:35 PM
NOLAMike's Avatar
NOLAMike
I went with TruckLite/Kury, both headlight and passing lamps. I'm very happy with them--they really light up the night. I ended up having to but the french trim rings to get the passing lights to fit properly though. You'll also want to consider the french trim ring for the headlight as it sticks out quite a bit from the stock trim ring. Even with the trim rings it's still a lot less $$$ than the HD ones. I spent the savings on other do-dads.
Old Jul 26, 2011 | 08:47 PM
AbnMP13's Avatar
AbnMP13
TruckLites; save the cash.
Old Jul 27, 2011 | 01:06 AM
luisan's Avatar
luisan
Got the HD LED set up on my 06 Ultra,perfect fit,looks good and original.I've also added the frenched trim rings to them.Just make sure you get the updated part # ending with an "A".
Old Jul 27, 2011 | 04:35 AM
Tx_Rider's Avatar
Tx_Rider
I went with the TL LEDs, fit was no issue, plug and play. I like the TL brand for their daylight visibility as well.
TL also makes the LED lights the military uses on tactical vehicles, they are combat tested so I'm sure they will hold up to anything we can throw at them.
