Ordered Clutch Spring 37871-98A
Old Jul 27, 2011 | 07:26 PM
Takedown's Avatar
Takedown
Default Ordered Clutch Spring 37871-98A
When I bought my 2006 SG the previous owner had installed the Barnett Heavy Duty Clutch spring because of slippage issues with the stock clutch after the engine build. The clutch did not seem bad at the time but after a year I have developed some tendonitis in the elbow from pulling the stiffer clutch (or at least I think that may be part of the issue). The last time the bike was dyno'ed it was right around 100 hp/ 100tq.
After reading quite a few posts I believe the stock clutch spring he replaced was the spring used for the reduced lever pull clutch which became the standard equipment that year. That spring from what I have read was a 300# spring. I am hoping that he went overboard with the Barnett Heavy Duty and I can get away with the 37871-98A spring which was used in big twins prior to '04'. This spring was from what I have read a 330# spring.
Anyone have experience with this lately? Do you think the 37871-98A will hold the clutch on a bike turning 100 / 100 ?
Old Jul 27, 2011 | 08:14 PM
dawg's Avatar
dawg
Yes it will hold. I run that disc instead of the stock disc
Old Jul 27, 2011 | 08:27 PM
Takedown's Avatar
Takedown
Thanks Dawg! It was actually your posting of the spring numbers and some other comments that led me to try that spring! I am hoping it works out and my elbow gets some relief.
Old Jul 27, 2011 | 08:49 PM
2009blackpearle's Avatar
2009blackpearle
Default held in mine
took my old spring from my old 2003 electra glide I think it is rated at 145kg/f as apposed to the new plates at 117kg/f i had a se plate in that was 175kg/f but it was killing hand . had bike on dyno at 98 hp and 107 tq
Old Jul 27, 2011 | 09:02 PM
Takedown's Avatar
Takedown
So the 145 KGF spring worked for you as well?
Old Jul 27, 2011 | 10:09 PM
stupid_rope's Avatar
stupid_rope
my -98A spring worked great and is easy to pull (to me, anyway)
Old Jul 27, 2011 | 10:26 PM
2009blackpearle
Default found list of part #'s I had
37889-06 (117 KgF) - Original in 96 cubic inch
37871-04 (135 KgF) my wifes dyna plate 2004 lowrider
37871-98A (145 KgF) - Most recommended on forum from what I can tell for touring 2003 eletra plate 37807-03 (165 KgF) - Used on Police models
37951-98 (175 KgF) - SE
145kg/f worked fine its the same plate u ordered I believe
Old Jul 28, 2011 | 05:40 AM
Takedown's Avatar
Takedown
Thanks for the replies. My elbow sure hopes it works out just as well on my bike. I just have to wait for the part to get here now. Kind of surprised the dealership did not carry it in stock. I suppose they sell more of the lighter springs.
Old Jul 28, 2011 | 02:48 PM
2009blackpearle
Default forgot to mention
write on your old one as soon as it is clean and oil free out of the bike. these things are not marked so if you mix them up you wont be able to tell one fron the other in most cases. the 117kg/f is thinner than the 145kg/f everything else looks the same so mark them if you have more than 1 . even the dealers cant tell them appart once they are out of the package.
Longridertx
2014-2024 Touring Models
Mar 9, 2016 06:37 AM
Ride my Seesaw
Aug 29, 2015 08:32 PM
stevemucha1
Jun 5, 2014 08:24 AM
Sharkman73
Mar 26, 2013 08:20 PM
corys87l
Feb 11, 2013 03:27 PM
