too much light maybe?
Old Aug 20, 2011 | 08:48 PM
fabrik8r's Avatar
fabrik8r
Default too much light maybe?
I installed the E-code Hella with 80/100 bulb a couple days ago. While cruising through town today my eng and batt warning lights came on, volt meter was low so I switched off the aux lights. Volt went back up and the warning lights went off. When I got out of town and got the RPMs back up, I switched the aux lights back on and no issues. I checked things out when I got home and aparently I have the 55 watt sealed aux lights, so I guess at low RPM all three lights are overwhelming the system. Maybe I'll try one of the lower wattage Osram bulbs. What's the max safe total wattage of all three bulbs at one time, on the OEM harness?
Old Aug 20, 2011 | 09:24 PM
Twinrider's Avatar
Twinrider
http://www.totalmotorcycle.com/photo...treetGlide.htm
According to the above site, your SG has a 650-watt charging system, just like my 2009 RK. I can run two sets of heated jackets and gloves, a heated seat and heated grips and my auxiliary lights all at once no prob. So there's no way your headlight bulb could overtax your charging system unless the charging system's not working correctly. Have your charging system checked.
Old Aug 20, 2011 | 10:09 PM
mkguitar's Avatar
mkguitar
a 100 watt light at 12 volts draws 8.3 amps--- add a bit for resistance in the wiring.
with your 2 X 55 and 60 lights on at the same time, you are using about 15 amps- no big deal IF your motor is turning highway revs- if you are at low rpms, the charging system is not producing enough current to keep up with the draw.
so when in town, don't use the big lights, as you will be sucking the battery faster than the bike can fill it
I ran 2 X 55 and 110 W ( with a Hella) on my Evo bagger for years- with a lesser rating charging system.
However, none of that ran through the factory harness as those bike would burn up the ignition switch if you added much draw on the stack harness.
and i wouldn't put that much current on my 09- they didn't design for it- and the cost of failure are high- the optics they use now are pretty darn good--- been spotting them Javalinas a little sooner on this bike.
mike
Old Aug 21, 2011 | 06:08 PM
fabrik8r's Avatar
fabrik8r
mike
I'm not running a 60w headlamp, but rather a Hella 100/80 bulb. I checked out the Hella site and I can't figure out if low beam is 80w or 100w, I've seen the same bulb represented as 80/100. Either way, in conjunction with the 55w X2 AUX lights, it exceeds the OEM 15 amp circuit, I'm either running 190w or 210w. I'm in agreement that the cost of failure is high so I'm looking at using one of lower wattage PIAA, just got to decide between star white and extreem white plus.
Old Aug 21, 2011 | 06:44 PM
jberg's Avatar
jberg
High beam is 100w. Many parts of the system are subject to burnout including light parts and wires. If you continue to use the lights at least make sure you use an appropriate relay.
Old Aug 21, 2011 | 09:46 PM
Mick's Avatar
Mick
If you're going to run a light with that much wattage , you should really run a relay to boost efficiency and save the stock switches from that much amperage.
This guy offers some really neat , well made relays for bikes.
http://easternbeaver.com/Main/Produc...s/h4_kits.html
The H4 Single Relay Kit would be super for your project.
Even a high output charging system may not have enough guts at low RPM's but at highway speeds can keep up with the load no problem.
I had good luck running an Osram 70/65 H4 bulb , the first number is always the low beam wattage.
Bear in mind high wattage bulbs "usually" have shorter lifespans than standard wattage bulbs.
Mick
Old Aug 21, 2011 | 10:18 PM
mkguitar's Avatar
mkguitar
or get a relay kit from pep boys for $17.
relay, wire connectors etc. in the off road light section.
and definitely go to high temp socket for the headlamp, also pep boys
you are right about that 15A fuse, you are marginal on that circuit ( although i am looking at 2009 manual- the evo was different altogether, and then I rewired it)
15.83 A low beam and spots, 17.5 high and spots.
probably add .5 for wiring, switches, sockets etc.
mike
Whodey
Oct 24, 2016 08:12 AM
choo53
Apr 16, 2010 10:31 AM
jerem515
Feb 8, 2008 07:29 AM
ninetyfivebravo
Jan 17, 2008 08:04 PM
Sanford
Apr 30, 2006 12:55 AM
