Changing rrear shocks
Old Sep 2, 2011 | 10:00 AM
jackinthebox's Avatar
jackinthebox
Default Changing rrear shocks
When changing out rear shocks do you guys take both old one off then install new one or do one side at a time? Thx
Old Sep 2, 2011 | 10:10 AM
berniemc's Avatar
berniemc
Jack it up and then put a block of wood under tire and you can change out both at same time
Old Sep 2, 2011 | 10:16 AM
vtwinbob's Avatar
vtwinbob
i used a small floor jack to put under the rear tire, that way you can move it up or let it down if need be.
XARAN's Avatar
XARAN
If you are replacing with the same size it can be done on the ground 1 at a time. We just swapped out my buddies SG for Progressive 940 and had to put it on a jack because the 940 are 1" longer unloaded and then they "sag " to the same lowered height as the stock SG shocks.
On a side note I rode my friends bike and the 940 Progressive shocks are a big improvement over the stock air set up. Id really like to ride a bike with both the HD premium Touring and Ohlins to see if I can tell the difference .
Old Sep 2, 2011 | 10:19 AM
mkguitar's Avatar
mkguitar
...jack it up just a few inches--- careful that if you are working at the back you don't shift a balance point and the bike nosedive forward.
so just a couple of inches.
I have a wedge shaped block of wood which I use to position the wheel in relation to where the shock eyes are positioned.
old air shocks? store up right to keep the oil in, a little tape over the fitting for dust
----- drain all air from the system before starting, to keep the oil inside the shocks/lines
mike
Old Sep 2, 2011 | 12:26 PM
jackinthebox
Thanks, Im actually going from stock 13" to 11" on my RK. The shocks are lowered from bitchin baggers.
Old Sep 2, 2011 | 01:13 PM
mkguitar's Avatar
mkguitar
cool,
watch for tire bottoming out in the fender, it'll eat up your wiring,
if so,you have to rewire the taillights etc.
mike
Old Sep 3, 2011 | 08:39 AM
fat daddy's Avatar
fat daddy
Shocks from bitchin baggers wont let fender and wheel touch,they do a good job
robbyville
Mar 26, 2016 07:44 PM
skiddd
Sep 5, 2014 02:54 PM
hog indo
EVO
Sep 29, 2012 08:29 PM
jimmything
Nov 9, 2008 09:22 AM
cHarley
Mar 12, 2007 05:21 PM
