More chargeing problems
Old Oct 28, 2011 | 09:14 PM
Trucky911's Avatar
Trucky911
Got my bike back today with the new stator rotor. It was back ordered so it finally came in yesterday and it got installed. Picked it up this morning and all seemed well until about half way home and the voltage started to drop at idle again. The voltage measured with a volt meter was only 12.2 vdc. Went back to the dealer and they checked out every thing and could not find any thing wrong but they agreed to change out the volt regulator. Now I have 13.9 to 14.1 volts all the time. So a voltage regulator can check out good but still be bad......
Trucky911
Old Oct 28, 2011 | 10:42 PM
mkguitar's Avatar
mkguitar
this may not apply, but alot of times the "fix" is in just renewing the connections- I work with electronics and 80% of the time is a dirty connection, loosen, clean, tighten will fix--- same things done when a part is replaced.
Mike
Old Oct 29, 2011 | 08:04 AM
Trucky911's Avatar
Trucky911
Thanks mk, I tried all that and it it didn't work. I'm back on the road again and all is well and I'm happy.....
Trucky911
Hipolito
May 31, 2013 08:55 PM
wjl24
May 24, 2011 11:22 AM
jacknthebox
Aug 5, 2010 08:20 AM
glenns
Jun 26, 2009 02:19 PM
Sleeps In Trees
Oct 23, 2008 07:52 PM
