se compensator
Old Dec 14, 2011 | 09:22 AM
  #61
MILLER41143's Avatar
MILLER41143
i am going to take the starter to the starter guy on my lunch break and have him test it.
I have another question, I am going to take off the true dual system and go with a 2 into 1 pipe, can i get rid of that bracket that is inbetween the starter and the primary or do i have to leave it in their for spacing?
also here is another video
http://www.youtube.com/watch?v=w5g86lIrl0U
Old Dec 14, 2011 | 10:26 AM
  #62
X Iron Butt's Avatar
X Iron Butt
[quote=MILLER41143;9142547]
that bracket that is inbetween the starter and the primary or do i have to leave it in their for spacing?quote]
My exhaust bracket is not between the starter and primary. It is on the right/outboard side of the starter. The starter touches the primary direct. If this is how you have it mounted it might be the problem.
[quote=I have another question, I am going to take off the true dual system and go with a 2 into 1 pipe, can i get rid of that bracket that is inbetween the starter and the primary or do i have to leave it in their for spacing?quote]
My Vance and Hines exhaust system came with a new bracket that replaced the HD in the same location just different shape,
Last edited by X Iron Butt; Dec 14, 2011 at 10:32 AM. Reason: took video out covering text
Old Dec 14, 2011 | 12:06 PM
  #63
MILLER41143
this is how i have it mounted inbetween the starter and the primary i will look at my service manual when i get home nd see if this is the correct way to install it.
or if anyone has a manual for an 05 w/ true duals from factory that could tell me
Old Dec 14, 2011 | 12:11 PM
  #64
MILLER41143
[quote=X Iron Butt;9142740][quote=MILLER41143;9142547]
Originally Posted by I have another question, I am going to take off the true dual system and go with a 2 into 1 pipe, can i get rid of that bracket that is inbetween the starter and the primary or do i have to leave it in their for spacing?quote
is your vance and hines 2 into 1 or is it 2 innto 2 i was thinking if it was a 2 into 1 system that the bracket would not be used since their is no pipe crossing over on that side
Old Dec 14, 2011 | 04:22 PM
  #65
X Iron Butt
is your vance and hines 2 into 1 or is it 2 innto 2 i was thinking if it was a 2 into 1 system that the bracket would not be used since their is no pipe crossing over on that side[/quote]
I have true duals but my point is the exhaust manufacturer will supply a bracket if one is needed. Most of the larger manufacturers have a pdf on their website of the installation instructions. You may be able to see there or call them about the bracket.
Old Dec 14, 2011 | 05:51 PM
  #66
Fire-Medic's Avatar
Fire-Medic
Which 2-1 system are you going with?
Old Dec 14, 2011 | 09:01 PM
  #67
MILLER41143
The bracket was my problem I had in between the starter and primary and that spaced the starter out too far. Thanks for all your help. It is starting perfect now!
Old Dec 14, 2011 | 09:08 PM
  #68
soft 02's Avatar
soft 02
Glad you got it to all worked out!
Old Dec 14, 2011 | 09:45 PM
  #69
X Iron Butt
Great Job. Just think how easy it will be next time.
gnaz
Aug 27, 2018 09:30 AM
speakerfritz
Jul 14, 2012 01:08 PM
2004Sierra
Mar 26, 2012 04:04 PM
FloridaFLHX
Sep 11, 2010 12:38 PM
Mikind7
Jan 11, 2010 11:43 PM
