View Poll Results: How many went with a FM 107 instead of purchasing new ??
Went ahead with FM 107
19
47.50%
Bought a new bike
10.00%
Went bigger with another manufacturer (S&S, Drago's, etc.)
5.00%
Other
15
37.50%
Multiple Choice Poll. Voters: 40. You may not vote on this poll
FM 107 Poll
Old Dec 4, 2011 | 02:03 AM
Gearhead3's Avatar
Gearhead3
Originally Posted by scottycameron
So far so good man, they did the $30 stiffer springs or plates, clutch is a bit harder to pull in but i can live with that. It was that or spend another 250-ish to get a new heavier duty clutch.
Here's a list of available clutch springs. I, along with many others, have gone with the 98A spring. There is a noticable increase in clutch pull but you get used to it real quick. I was having slippage problems in fifth gear at moderate to heavy throttle and installing the 98A spring cured it. My Cousin has the 37951-98 SE spring on his and it's STIFF. It feels as if the cable needs lubed real bad.
37882-06 blue dot (117 KgF/258 lbs/ft) 2006-88", 2007 thru 2010-96"
37871-04 yellow dot (135 KgF/ 298 lbs/ft) 2004-05 88" and 2010 Limited
37871-98A (145 KgF/ 320 lbs/ft) 1998-2003 Most recommended on forum for touring
37807-03 pink dot (165 KgF/ 364 lbs/ft) 2007 thru 2010-103 "Police"
37951-98 (175 KgF/ 386 lbs/ft) Current SE
Old Dec 4, 2011 | 02:30 AM
sublime_ac's Avatar
sublime_ac
I don't see the reason to buy a new bike.. Seriously, if you have a solid touring rig why not just upgrade it to be what you want? The last few updates to the platform are not that significant and none of the shortcoming in the earlier models cannot be overcome with a little investment and work.
Yeah a shiny new bike is nice, but if you have been taking good care of your bike it should still look pretty shiny and clean like a new bike.
I did a 107" build, Axtell bored stock cylinders, 20 degree pistons, baisley heads, SE pro 50mm throttle body, feulling oil pump, se cam plate, b lifters, se compensator, woods tw-408-44 cams... Smooth acceleration in any gear / speed, 38mpg, estimate 110/120, haven't dynoed the bike yet, I have a thundermax ecu.. My buddy has a dynoed bike with a very strong 95" he has 102 / 110 and I start pulling away from him by the time we hit second gear.
jai yen yen
Feb 22, 2018 07:24 PM
BLKPRLFLHTCU
2014-2024 Touring Models
Oct 27, 2014 06:46 PM
steveh326
Jul 8, 2014 07:20 PM
jlacasci
Screamin Eagle CVO Models
Sep 9, 2012 02:18 PM
webbhead
Jul 5, 2011 07:28 AM
