Question on Neutral Light
Old Dec 9, 2006 | 06:58 PM
bradteed's Avatar
bradteed
Default Question on Neutral Light
I was working on the bike today - installed my new crash bar and the Fullsac dual conversion. Everything went fine....But, when I went for a short test ride and came home to park the bike, I realized that my neutral light was not working.
I've owned several Harley's and never had an issue with the neutral switch. Anyone had an issue with the Neutral Switch going bad?
Could it be something else?
Thanks for any comments.
Old Dec 9, 2006 | 07:15 PM
jeepster09's Avatar
jeepster09
Default RE: Question on Neutral Light
It is on top of the transmission. Take it out and clean it off with brake cleaner, sometimes they get dirty and the ball does not make contact. It is only a metal ball with a spring that completes the circuit to ground. Mine has acted up a couple of times.
Old Dec 9, 2006 | 07:58 PM
Dogwood's Avatar
Dogwood
You probably just dislodged or damaged the wire going to the neutral switch.
As jeepster09 said, it's on top of the trany just below where you working on the rear cylinder exhaust port.
Dazzauk
EVO
May 9, 2016 02:36 PM
scott01
Aug 25, 2014 07:10 AM
stevepacman
May 24, 2008 12:24 PM
Jimbo192
Sep 23, 2006 07:22 PM
mradl2
Aug 6, 2006 02:19 AM
