Below the tail light lic bracket
Old Jan 7, 2012 | 12:53 PM
kingomtn's Avatar
kingomtn
Default Below the tail light lic bracket
Has anyone used or seen softbrakes plate relocator?
I'm curious as to if it creates an issues because of the resulting gap between the turn signal bar and fender.
Are there any other means to relocate the plate below the taillight?
I realize I'll need to wire a new plate light.
Old Jan 7, 2012 | 01:04 PM
mkguitar's Avatar
mkguitar
This is my 09 FLHTC with the tour pak off. That is a 2010 road king signal bar ( it is narrower and has integrated plate light.
2 bolts.
bought cheap from another rider here on the forums.
plate light power, you may need to splice in depending on what you have going on ( you don't list year/model.
Mike
Old Jan 7, 2012 | 01:08 PM
kingomtn's Avatar
kingomtn
My bike is an 04, will the later model fit it?
I'll add my bike to sig line.
Old Jan 7, 2012 | 01:12 PM
mkguitar's Avatar
mkguitar
no, the later rear fender is wider, the electrical plugs are all different.
there are options for you.
if you use that style bracket ( in 1st post) use rubber washers sandwiched to protect paint etc.
and you can buy plate mounting bolts with leds in them. ebay or if you have a cycle gear chain store near you.
custom dynamics also has them on their website ( about $12)- and you can sort out the wiring to your taillight.
Stand by for more posts from guys who have already done this mod to similar year/model bike
mike
Old Jan 7, 2012 | 01:20 PM
Keithhu's Avatar
Keithhu
I bought mine a few months ago, it had a rubber bumper on the back of it.
Call the guy on the web site, they're pretty responsive.
I'd also suggest a Radiantz LED licence bracket, it rocks!
Here's my Softbrake/Radiantz combo on my 2012 FLHRC
Old Jan 7, 2012 | 01:34 PM
Harleypingman's Avatar
Harleypingman
RK Classic, Custom, or Standard?
Lots of guys have used the SB plate relocator on your model. JP used to offer a tail light lens with the clear portion on the bottom to light the license plate; haven't checked in several years if they still do.
You could use the SG turn signal bar since it has LED's in the center portion to light the license plate.
Carl
Old Jan 7, 2012 | 01:55 PM
kingomtn's Avatar
kingomtn
It's an o4 std. I like the led plate frame. Will check into that one.
Old Jan 7, 2012 | 02:25 PM
Keithhu's Avatar
Keithhu
It lights the plate VERY well. Here's a link: http://www.sears.com/shc/s/p_10153_1...=SPM1771831701
Some advice - don't use the bolts they give you, they are *tiny* allen heads, a pain in the rear. Go to the hardware store and get flat head machine screws like this one:
Old Jan 7, 2012 | 03:53 PM
kingomtn's Avatar
kingomtn
got you on the hardware. Looks like I'm ready to clean up the rear a little.
Old Jan 7, 2012 | 04:22 PM
Keithhu's Avatar
Keithhu
Amen bro, those tail lights on the road kings and heritages need it.
