Brake lines - chrome on top, black on the bottom
Old Jan 11, 2012 | 05:24 PM
Keithhu's Avatar
Keithhu
Default Brake lines - chrome on top, black on the bottom
I have a black RKC, I like the way the black brake lines blend in with the fender on the bottom, but I like stainless with the bars. There is a "junction point" under the trees where the front brakes split off from a single line into 2 cables to the calipers.
I'm getting new bars and cables soon, so I'm trying to decide what to do.
Has anyone done this combo?
Old Jan 11, 2012 | 08:33 PM
Keithhu's Avatar
Keithhu
Ok, a bit of a goofy question, I'll admit, but still curious to see if anyone's done it, so I thought I'd poke it back up to the top to see if I get any takers.
Old Jan 11, 2012 | 08:49 PM
Redbeard719's Avatar
Redbeard719
I'm not sure that the manifold comes apart.
On my bike, since I have ABS, this would be as simple as only replacing the lines from the MC to the ABS module.
If you have ABS, you could go that route.
Old Jan 11, 2012 | 09:52 PM
VinnyM's Avatar
VinnyM
On my 11 RKC it's a one piece line, you can go Drag Specialties and it's a two pieces that you can probably do what you want but you will have to replace the top and bottom lines.
Old Jan 11, 2012 | 11:48 PM
99Roady's Avatar
99Roady
Not sure if it will be much help but heres a little bit of visual for you. I have not done this but just happen to have two complete front brake line sets in Sterling Chromite and Black Pearl so I could mix them for you. I suppose it would look a little better on the bike. These are all Magnum Shielding cables and you could find the proper part numbers on there website for your particular model.
Old Jan 12, 2012 | 04:53 AM
Keithhu's Avatar
Keithhu
Super, thanks! Dealer is doing the work, I will show them this pic if they give me any razzmatazz about being able to do it.
Old Jan 12, 2012 | 10:56 AM
SCJE8's Avatar
SCJE8
I did it with my ABS equipped Street Glide! I had my powder coater 'ceramic coat' the junction point that bolts in under the triple tree and the lower connection points. Looks great! We used the non-heat activated ceramic coating as not to have problems with the clear plastic jacketing.
Good luck...
Steve
Old Jan 12, 2012 | 11:19 AM
Keithhu's Avatar
Keithhu
Good luck...
Steve
Thanks, Steve! Frankly I don't think the coating is necessary on the junction, you cant see it underneath there anyway
caulk04
Sep 17, 2018 04:36 PM
DrPlastic
Oct 22, 2017 07:50 PM
nightrain116
2014-2024 Touring Models
Nov 3, 2015 01:31 PM
BillinSC
Mar 26, 2013 08:12 PM
Terrabella
Dec 28, 2011 11:48 AM
