Electrical buzzing sound Help
Old Jan 17, 2012 | 07:03 PM
L3ft2's Avatar
L3ft2
Default Electrical buzzing sound Help
2006 FLHRCI
I am noticing a constant electrical buzzing sound that I isolated to the fuel gauge area.
When the ignition and run is on the fuel pump engages then shuts off (as normal) and the buzz is not present. Also, the gauge goes from "E" to the correct fill level.
Once the bike is started the buzzing begins. The gauge light is working and it is registering the fuel level correctly.
This is probably unrelated but I just changed the battery.
Any help would be appreciated. I don't want something to burn up and cost the big bucks if I can prevent it now.
Old Jan 17, 2012 | 07:16 PM
mkguitar's Avatar
mkguitar
I would suggest the fuel pump
or ignition noise in the radio ( change to awesome mystery extreme performance sparkplugs or wires lately ?)
Mike
Old Jan 17, 2012 | 10:45 PM
BBStacker's Avatar
BBStacker
Can't help ya out but this should be an interesting problem.
Just curious though, how the heck did you hear that over the engine?
Old Jan 17, 2012 | 10:46 PM
z71_fourwheelin's Avatar
z71_fourwheelin
i would suggest unplugging the gauge and seeing if the buzzing still exist. sounds more like a speaker issue.
Old Feb 1, 2020 | 03:36 PM
Adam Dobler's Avatar
Adam Dobler
Stage I
Default Same problem
Hey man I’m just curious if you figured out your issue . My Dyna StreetBob is doing the same thing
Old Feb 1, 2020 | 05:02 PM
Keithhu's Avatar
Keithhu
7 years later, he might still be alive.
hoosierbagman
General Topics/Tech Tips
Dec 20, 2015 08:51 PM
BKDeuce
Apr 3, 2015 03:48 PM
kryingame
Screamin Eagle CVO Models
Sep 18, 2014 02:34 AM
pepe3rd1
2014-2024 Touring Models
Sep 2, 2014 10:18 PM
CobraEd
May 11, 2013 08:06 AM
