Switched circuit adapter harness
Old Jan 18, 2012 | 03:23 AM
boardy's Avatar
boardy
Default Switched circuit adapter harness
H,i
I am wiring my engine bar lights to the accessory plug on my '09 RoadKing so that they can be controlled by the spare switch (thanks to the info I have got off this site).
If I add the the switched circuit adaptor harness (part # 70264-94A) will I be able to run a power lead as well to charge my TomTom?
Any advice will be most welcome.
Cheers,
Chris.
Old Jan 18, 2012 | 05:44 AM
z71_fourwheelin's Avatar
z71_fourwheelin
are you wanting the power lead to be controlled by the switch if so tap into the orange/red wire. If you are wanting power with ignition that tap into orange/white wire
Old Jan 18, 2012 | 10:46 AM
boardy's Avatar
boardy
Default Deutsch Connector Pins
Thanks for the reply.
For the lights I will be using 2 of the pins in a new, male, Deutsch connector (orange and black) so they can be turned on with the spare switch on the left hand side of the nacelle.
For my TomTom I want the power to be live to it when I turn the ignition on. Which pins would I need to connect to another male Deutsch to do this?
Hope that makes sense.
Regards,
Chris.
Old Jan 18, 2012 | 11:42 AM
z71_fourwheelin
Pin 1+4 for switched lights and Pin 3+4 for hot to Gps. PM me with any other issues.
Old Jan 19, 2012 | 02:40 AM
boardy's Avatar
boardy
Thanks very much for that, it's much appreciated. All I need now is to set some time aside to do the job.
Regards,
Chris.
Old Jan 19, 2012 | 03:09 AM
mkguitar's Avatar
mkguitar
question: would it be impractical to have the sat nav on a switch ?
reason I ask is if it gets power with ign. on, can the sat nav suffer any ill effects from the voltage drop when the starter is operated-?
Mike
Old Jan 19, 2012 | 04:53 AM
z71_fourwheelin
Most GPS are battery run with 12v to recharge. so the drop from starter use will not affect performance/ill effects of GPS
bladeguy
Jul 14, 2016 01:50 PM
IronWright
EVO
Jul 29, 2012 04:39 PM
boardy
Mar 15, 2012 05:13 AM
speakerfritz
May 23, 2011 08:07 PM
Hoopman
Oct 12, 2005 02:14 AM
