Project "Cheapskate"
Old Mar 3, 2012 | 09:41 AM
  #281
Deuce Bigelow's Avatar
Deuce Bigelow
Batman,
not sure you caught this in the pic that you have of the CVO bike..
but the "silver" on the front fender of the CVO bike is actually brushed sheet metal, not paint.....
just an FYI..
Old Mar 3, 2012 | 09:53 AM
  #282
teeboz's Avatar
teeboz
Man, I love the green color!
Old Mar 3, 2012 | 10:03 AM
  #283
Wally's Avatar
Wally
Originally Posted by Deuce Bigelow
Batman,
just an FYI..
You're not raising the bar on poor Batman are you Deuce?
Old Mar 3, 2012 | 10:15 AM
  #284
Batman7349's Avatar
Batman7349
Batman,
just an FYI..
Well that ain't going to happen, brushed sheet metal that is!!!! Looks nice but I'll be using Harley Brilliant Silver, and instead of black I'm using a Dodge Brilliant Black Pearl.
Old Mar 3, 2012 | 10:27 AM
  #285
Batman7349's Avatar
Batman7349
Headed out to the shop about 08:00. Sanded the front fender with a DA sander with 320 grit paper to prep the primer surfacer from two weekends ago.
Then lightly went over it with grey 3M scotchbrite
After the sanding I wiped both sides of the fender down with wax and grease remover, I start wearing blue nitrile gloves at this point to eliminate the chance of oil from my hands contaminating the surface. PPG DX440 or a generic both work well for this. Wipe on with one cloth, then wipe dry with a 2nd clean cloth.
I decided that I would have more sealer than I needed for just the fender so I decided to paint the side covers today also. I had to remove the clear plastic protector that Harley puts on.
And of course it leaves some residue behind, so the best product for removing glue is 3M General Purpose Cleaner. It works great for removing residue after de-badging or after pin-stripe removal.
Next I mixed up a batch of Transtar 6234 Kwik Seal. I really like the Transtar line of primer surfacers and sealers. Less expensive than PPG and does not shrink back like Omni or some other inexpensive products.
Loaded up the little FX100 gun and applied 1 wet coat to the fender and side covers.
Now let them dry for about 30", then I'll apply 3 coats of green and let sit for 60" before I start taping.
Old Mar 3, 2012 | 01:52 PM
  #286
Wally's Avatar
Wally
Would that 3M stuff work good for removing the residue left over from duct tape? I had to duct tape my sadlebag lid shut last fall, cause some screws fell out. I didn't get around to removing the sticky stuff before it went away for the winter, so It's on my list of stuff to do when it comes out of storage.
Old Mar 3, 2012 | 02:05 PM
  #287
traveler's Avatar
traveler
did you paint the inside of the fender as well? Just curious...
Looks great!
~Joe
Old Mar 3, 2012 | 03:56 PM
  #288
ndfrspd's Avatar
ndfrspd
Default duct tape glue
Not to Hijack but. Wally to remove the duct tape glue safely, soak the area with WD40, (trying not to get any on the semi-gloss black surfaces of inner bag as it will make this area glossy) work it in gently with a soft towel of some sort, You will be suprised at how quick and clean this job is. The WD40 just melts the glue without harming the paint. Good luck, ndfrspd
Old Mar 3, 2012 | 05:28 PM
  #289
Batman7349's Avatar
Batman7349
Yes the 3M adhesive cleaner will work excellent for that. However I would try the WD40 trick 1st since the 3M stuff will set you back 10 or 12 bucks.
Old Mar 3, 2012 | 05:29 PM
  #290
Batman7349's Avatar
Batman7349
Looks great!
~Joe
Joe, No I didn't paint the inside, but I will spray it with a rubberized undercoating to keep any gravel or rocks from kicking up and possibly denting from the underneath.
