Buzz through speakers
Old Oct 4, 2020 | 12:16 AM
Jbpooh's Avatar
Jbpooh
Originally Posted by Harleypingman
First, the RF amp installation instructions say to ground the amp to the frame; not the battery. They also say the ground wire shouldn't be longer than 30", so going to the battery exceeds that recommended length.
As previously mentioned, there is a grounding screw on the upper triple tree. It's relatively easy to access with the fairing cap removed.
Alternatively, and although it's slightly longer than 30", there are two grounding studs in front of the battery, just to the rear of the gas tank. One will have the cable from the battery negative terminal. Use the other one located nearby.
To exclude the BAL tail light as the culprit, disconnect the BAL tail light and see if you still get any "noise." Also try it with the OEM tail light installed.
Good luck with finding a solution.
Carl
I know this is really old, but I can not for the life of me find that grounding screw yall mentioned near the tree. Anyone have a picture or better location? I just installed an Aquatic and new amp and it has a bussing noise. 🤬🤬
Highwayman-AL
Audio Systems
May 13, 2017 06:28 PM
woodwarda99
Audio Systems
Nov 27, 2016 10:35 AM
streetglide13
Audio Systems
Mar 5, 2015 02:03 PM
jcain
Audio Systems
14
Mar 18, 2014 05:07 PM
Ryder7140
Audio Systems
Jun 1, 2013 05:13 PM
