What a day...
Old Feb 4, 2012 | 03:34 PM
FL-kruzen's Avatar
FL-kruzen
Default What a day...
When I changed my lower fork tubes a couple of weeks ago, I noted the front forks wouldn't hold air. So I changed the "O" seals on the Banjo fittings on top of the forks. It still didn't hold air. So today, I take the banjo bolts out and take it to my local HD stealer and they don't sale replacements. It comes in a kit...that includes the two banjo fitting the 3-way connector and new air hose for $72.00! So I get new hose line and when I get home, I freaken lost the banjo bolt! How can this happen!
I said the hell with it and went to Ace hardware and bought two 71/6 x 1" stainless bolts and just plugged the holes. Oh, while I was at it I replaced the front brake pads. Got new brake pads from ebay for $ 18.00 for all four in Kevlar. Harley wanted $42.00 a pair. I least I did get an hour ride in this afternoon. It's always something. Does anyone have one of those banjo bolts laying around they might want to part with?
Old Mar 31, 2012 | 01:02 AM
C.H.L.'s Avatar
C.H.L.
Banjo Bolts just suck - haha
Hope you turned out ok. I installed a stage 1 screamin eagle air filter kit on my road king today, and I miss read the instructions. It says tighten the banjo head bolts to 120 inch pounds..... I set up my torque wrench on foot pounds. - pulled the head threads out with the bolt.... jeez!!!!!
Like you, i put a 3/8 longer bolt in and said to heck with it. I really don't see the point in the banjo bolt for my application anyway.... check out the video I made, I just don't see what it is doing.
http://www.youtube.com/watch?v=MuKVexRoM9E
Old Mar 31, 2012 | 01:08 AM
mkguitar's Avatar
mkguitar
...to release breather pressure from the heads.
you are asking for trouble if you try running your bike like this.
looking at your video:
from the area between the 2 seals, is a passage running toward the throttle body throat ( by your left thumb at the beginning of the video, and on the backside you can see the casting where the passage runs)
so the piston goes down into the case-either on the intake or power stroke, as it goes down it pushes air and oil up to the heads.
there is an umbrella valve ( one way valve) in the heads which helps to separate most of the oil from the mist, but the air mist that exits the valve, goes into that banjo bolt, then thru the backplate to the intake where it is burned.
If a solid bolt is put in the head the pressure will find a way out, maybe pushing a gasket or seal out in front of it
you gotta fix it right, maybe a helicoil in the head
a torque wrench that goes past 40 ft pounds is not going to be used often on your bike--- and with experience, you will notice that steel bolts into aluminum are not torqued very tightly.
Mike
Old Mar 31, 2012 | 02:02 AM
DOMAPOI's Avatar
DOMAPOI
Definitely got to fix it! Yes, a helicoil is the answer or replace that part of the head that the threads were ripped out of. Your head has to breath or that pressure will go back into the case and up the other head which will probably cause it to blow more oil from the head that is still vented. Either that or if you know someone that has good machining skills he can turn that new longer bold into a banjo bolt.
Old Mar 31, 2012 | 07:28 AM
C.H.L.'s Avatar
C.H.L.
Thanks guys. Looks like I'll try to get a half inch longer banjo bolt to just go into the threads that are back there. But if not, I will do a helicoil.
Thanks!!!!!!!!!!!
Old Mar 31, 2012 | 08:09 AM
C.H.L.'s Avatar
C.H.L.
Ok Guys,
I'm going to use a helicoil today. That is also what my father-in-law suggested, right off the bat.
One last question, I have this stock black bracket over the head threads.... I've seen it removed on some applications..... Should I remove my black bracket for the regular Stage One Screaming Eagle Air Kit I'm putting on????
THANKS GUYS!!!!!!!!!!!!!!!!!!!
Attached Thumbnails What a day...-screaming-eagle-air-filter-10-large-.jpg   What a day...-screaming-eagle-air-filter-13-large-.jpg
Old Mar 31, 2012 | 10:10 AM
C.H.L.'s Avatar
C.H.L.
Nevermind.... I just saw in the instructions to remove it.... I missed that part I guess.
Old Mar 31, 2012 | 11:45 AM
mkguitar's Avatar
mkguitar
careful you don't scratch the underside of your tank- instructions say to remove it, some guys loosen it and block it up out of the way.
or tape cardboard to protect it from slipping tools.
another reason why i suggest the ness big sucker, is the easier install, that bracket stays in place
and lower cost ( $120)
and chrome backing plate looks better against the motor
and washable oiled filter media
Mike
Old Mar 31, 2012 | 01:25 PM
C.H.L.'s Avatar
C.H.L.
Got it guys!!!!!
Yeah, I didn't remove the tank, I dremmeled the old bracket off
My father-in-law suggested a helicoil yesterday.... I had never done one, so was nearvous about doing it!!!!
But I did it today, it went great, and all is right with the world again!!!!
WOOOOO HOOOOOO
Attached Thumbnails What a day...-helicoil-3-large-.jpg   What a day...-helicoil-4-large-.jpg   What a day...-helicoil-5-large-.jpg   What a day...-helicoil-7-large-.jpg   What a day...-helicoil-8-large-.jpg
Old Mar 31, 2012 | 03:43 PM
mrfikser's Avatar
mrfikser
you need to give you father in law something nice for his birthday...
Crueltiming
Engine Mechanical Topics
11
May 13, 2019 06:03 AM
Z
May 21, 2018 03:55 AM
johnod
EVO
16
Feb 27, 2017 12:21 PM
kino44
EVO
Jul 1, 2014 02:47 AM
BigJim8765
Exhaust System Topics
13
Feb 8, 2010 12:20 PM
