Rider backrest
Old Feb 9, 2012 | 09:48 PM
  #31
Wassup8687's Avatar
Wassup8687
I have the Harley adjustable and love it. You csn adjust it on the fly depending on how your back is feeling.
Old Feb 9, 2012 | 10:19 PM
  #32
GLACIERPEARL's Avatar
GLACIERPEARL
Can anyone suggest the better/best backrest for my '06 Ultra ???
Old Feb 9, 2012 | 10:28 PM
  #33
BugBYter's Avatar
BugBYter
Originally Posted by roox
Non adjustable is fine. It took me a couple of tries with the different setting for the base but I found the sweet spot and its great now.
Which holes did you use for the base (over the studs)? I have mine in the rear (top) holes with the base in it's most forward position. I also tried the 2nd holes from the rear. Neither really centered the backrest in the seat slot.
Old Feb 9, 2012 | 10:39 PM
  #34
BugBYter's Avatar
BugBYter
Originally Posted by X Iron Butt
...... After about 500 miles of looking at the position of the rest I figured out it is not pushing me any further forward but making me sit up straight. .....
That's it exactly.
Long days are much more comfortable sitting up straight. Once your straight you need to adjust your highway pegs, controls, bars and shield height to keep you that way.
Old Feb 9, 2012 | 10:55 PM
  #35
X Iron Butt's Avatar
X Iron Butt
GP
Mine was made to match Road Zeppelin seat and it has a sharp vertical V shape in the center. It is not adjustable and as you can see here there are a lot of opinions on that. I thought it might be a problem when I first installed it but I think it really helps for comfort over the smooth/straight accross models. It seems to fit my backbone better. I think this kit has been discontinued but here is the P/N if you want to search for it. 52336-97. I just bought it a few months ago so they are still out there.
Hope this helps.
You may need a seat belt to keep your sound system from blowing you off of the bike ;-)
Old Feb 9, 2012 | 11:04 PM
  #36
X Iron Butt
Originally Posted by BugBYter
That's it exactly.
It takes a while to get used to the new position after riding the other way but now I don't want to ride without it.
I used the holes that position the bracket all the way back on the fender studs and the front strap is adjusted to position it all the way back also. It started out looking funky but the seat slot has conformed to that position and it looks fine after 100 to 200 miles. .
Old Feb 10, 2012 | 05:37 AM
  #37
Trailfndr's Avatar
Trailfndr
had the Adjustable HD backrest on my 06 Ultra, LOVED IT...Traded in for the 08, and kept the backrest. Mounted the control lever on the heat shield (drill a hole, cut out to size, and 2 little screw holes) WILL NOT Ride without it.
Nightrain04
Feb 20, 2017 03:53 PM
Challenger
Aug 2, 2011 11:11 AM
the_ogre25
EVO
May 20, 2009 10:13 PM
gearheadfmc
Jan 6, 2008 09:46 AM
whateva
Aug 5, 2006 11:50 PM
