12 inch yaffe monkey bars- what cables??
Old Mar 13, 2012 | 11:07 PM
ringer19's Avatar
ringer19
Default 12 inch yaffe monkey bars- what cables??
anyone who has installed the 12 inch yaffe monkey bars on a 2011 street glide? what cables did you use ? harley OEM? part #? i want to use a black braided style
thanks in advance
pics would be awesome
Old Mar 14, 2012 | 12:05 AM
BIGVTWIN's Avatar
BIGVTWIN
used magnum in black pearl. 8 in. over on the clutch and 4in. on the brake
Old Mar 14, 2012 | 03:39 AM
ringer19's Avatar
ringer19
thank you
Old Mar 14, 2012 | 07:43 AM
BIGVTWIN's Avatar
BIGVTWIN
If you put on the 12 then please buy some new riser bushings. I did not and had to go back and put them in. Inner fairing almost taken off again.Better to do it the first time.Helps alot with the handle bars swaying.
Old Mar 14, 2012 | 07:49 AM
ringer19's Avatar
ringer19
thanks for the heads up , i actually ordered 10 inch , misread my own email, the 10 inch have a 12 inch rise , i contacted yaffe to see if stock cables will work on the 10 inch , a few guys said they do .
are you happy with yours? comfy? good quality ?
thaks
Old Mar 14, 2012 | 08:00 AM
KeeBee's Avatar
KeeBee
I ordered this set for my 12" monkey bars along with the bushings.
http://www.directharleyparts.com/cab...es-p-2463.html
Getting them put on next week.
Old Mar 14, 2012 | 09:35 AM
hog95023's Avatar
hog95023
I used the kit HD sells for their 12 inch bars. I also used the diamond back braided cables so those are a different color than what u want
Old Mar 14, 2012 | 12:35 PM
rg_dave's Avatar
rg_dave
I have 12s. I went with Magnum Sterling Chromite. They have black. +8 on the clutch (probably could have gone +6) and +6 on brake. Make sure you get the upper and mid line for the brake.
With 10s I think you'll be fine with the stock brake length. I would extend the clutch 2" so it doesn't bind and you don't have to reroute the cable. You don't need wiring extensions for either. The 12s you just have move the plugs under the radio.
Old Mar 15, 2012 | 01:23 PM
BIGVTWIN's Avatar
BIGVTWIN
thaks
Absolutely love these bars both in comfort and looks. I was not a big ape bar guy but I understand now.
I am 6 ft 3 in and my arms are a little less than straight out from shoulder feels real comfy.
Good luck
Old Aug 8, 2012 | 01:21 PM
Big_Swede's Avatar
Big_Swede
5th Gear
For those that have ABS as I do, for the 12" Bars, do I still use +6 or +4 on the brake like length?
I'll prob stick with +8 on the clutch. Going with Magnum Shielding Black Pearl unless I find a better steal somewhere else.
Thanks!
Swede
WFO FXSTB
2014-2024 Touring Models
11
Jul 3, 2017 10:30 AM
kfchd
Oct 17, 2016 01:20 AM
apetterez
Jan 21, 2015 04:35 PM
Kbi83
Sep 14, 2012 05:53 PM
jknappy54
Jul 15, 2012 09:12 PM
