problems or paranoid after stage 2
Old Mar 15, 2012 | 12:34 PM
cellison1460's Avatar
cellison1460
Default problems or paranoid after stage 2
I have a 2011 ultra with 5000 miles on it. I just did a ton of work on it and now I'm a little paranoid.
I went from stock to: Rinehart slip ons on the gutted head pipe, thunder max tbw auto tune, SE stage 1 air intake (not the cone one), SE 255 cams, SE adjustable pushrods. I changed the three O rings during the cam swap.
At this same time I did the full 5000 mile service.
I have ridden about 300 miles and it seems to be doing well except for two things. I keep getting a very random but overwhelming smell of burnt oil. It is a strong smell then gone within 60-90 seconds. I have checked inside the new air filter and there is no oil in it from the breather.
My oil pressure also seems to be a bit low at times. Hot idle is between 5 to 8 but 2000 rpm is dropping down to 20.
Oil appears to be in the appropriate range when checked.
Old Mar 15, 2012 | 12:49 PM
RK14SGS's Avatar
RK14SGS
My 2011 SG drops oil pressure like that too when hot. You can check for sumping by removing the small hex plug under the cam chest and catch and measure the oil.
Old Mar 15, 2012 | 02:50 PM
cellison1460
Can you please elaborate on this for me. I'm not sure what hex plug your meaning or how much oil there should be. Thanks
Old Mar 15, 2012 | 03:35 PM
blusmbl's Avatar
blusmbl
There is a hex plug at the bottom of the cam chest. It's not the same one you use for an oil change, it's further forward than those. If you pull it and drain the oil only a small quantity should come out. When I did my cams I'd say maybe a cupful came out. If it's sumping there will be like a quart of oil in there.
Old Mar 15, 2012 | 04:13 PM
RHillbilly's Avatar
RHillbilly
Is that the plug that can crack the case when you remove it
Old Mar 15, 2012 | 04:23 PM
ocezam's Avatar
ocezam
Great tip guys, I wasn't aware of that. Just did my cams also. No weird smells though.
Old Mar 15, 2012 | 04:39 PM
cellison1460
If it ends up being full of oil what do I need to do to correct it
Old Mar 15, 2012 | 04:47 PM
RHillbilly's Avatar
RHillbilly
You might check the orings where your air cleaner bolts to heads if you dont put a little oil on them before you tighten they will tear
Old Mar 15, 2012 | 04:55 PM
ocezam's Avatar
ocezam
If it's full of oil, it's sumping. You'll have to go back in and re-do the three o-rings you replaced. It's good that you put new ones in, but it's possible they didn't seat correctly causing sumping.
Having said that, if it were sumping, I'd think you'd feel a power loss with the engine churning that oil. I doubt if it is sumping and it's nice to know you can check that w/o removing the floorboards, exhaust, and cracking the chest open again.
I did my cams two or three weeks ago. I have been extra aware of every little sound too. I understand your paranoia. Just take your time and think this through.
Old Mar 15, 2012 | 05:16 PM
iclick's Avatar
iclick
To the OP: I'm not sure you have symptoms of sumping, as in that case you would likely see low oil level and a performance decrease when hot, neither of which you mentioned. Not sure about the burnt-oil smell, but I would look around for any leak, especially those around the exhaust system. I would expect higher oil pressure than 20 at 2000 rpm, even when hot. I rarely see <32 (straight-up on the gauge) at any time except at idle, and no change after the cam swap. I also have a 96/255 combo.
