SG running like crap - any suggestions
Old Mar 15, 2012 | 12:55 PM
monumaker's Avatar
monumaker
Default SG running like crap - any suggestions
I had a plug thread going. Wanna try it here also.
I finally got a chance to ride my bike for the first time this year and it's running like $hit! Kinda weird though, it ran fine when I stored it. Filled the tank full with gas with sta bill and it sat in a heated garage all winter. Pulled it out twice and let it run for 20 min. Hopefully this isn't a bigger problem than fuel. Don't think it matters but it's a 10 SG 96" 9200 mi. w 555s, fat cats and a pc5. I put in new hd double platinum plugs put in fresh 93 octane gas and went on a 15 mile test ride. Unfortunately it's exactly the same. As I said before the bike was 100% fine before I parked at the end of November. Bike fired up and was fine for about 3 miles today. Now it's $hit. It will fire up and idle fine, it's once u hit the throttle it's like its not there. No power. 4 th gear at 55 felt like I was in 6th goin 55. What ya think?
Old Mar 15, 2012 | 12:57 PM
Keithhu's Avatar
Keithhu
I would check the electrical connections (ECM as well), drain the gas and add new, give her another try
Old Mar 15, 2012 | 01:01 PM
Xcrossbow's Avatar
Xcrossbow
Might sound crazy but have had to replace battery to correct similar situation.
Old Mar 15, 2012 | 01:09 PM
mkguitar's Avatar
mkguitar
probably un-related but those 20 minutes warm ups are not good for your bike.
You might reconsider that the next storage period.
It may possibly be a problem with the electrical connections with your PCV, try reconnecting it
Old Mar 15, 2012 | 01:22 PM
monumaker's Avatar
monumaker
Thanks guys.
Yea next year it will not get started at all. I've been advised that's not good on it.
Battery is fresh green of the tender.
I've looked over everything I can and its all plugged in and tight.
Should I try some FI cleaner? If so what brand?
Old Mar 15, 2012 | 01:27 PM
carpetride's Avatar
carpetride
Yes, actually running a HD motor is the LAST thing you would want to do. LMFAO
Old Mar 15, 2012 | 01:37 PM
longrideshields-1's Avatar
longrideshields-1
Premium Sponsor
Good luck, I have had to charge or condition my battery before, it helped a ton. I would have thought it to be a fuel issue but a properly charged battery is also important.
__________________
General Inquiries:
Info@LongRideShields.com
Sales and Marketing:
Sales@LongRideShields.com
Phone:
775.331.3789
Old Mar 15, 2012 | 02:02 PM
Keithhu's Avatar
Keithhu
During the winter for a short period of idle only, this is absolutely true, bad juju.
Old Mar 15, 2012 | 02:05 PM
Burch753's Avatar
Burch753
I've also heard the HD upgrade plugs (not sure if thats what you used) are complete garbadge.... from my dealer...
Old Mar 15, 2012 | 02:09 PM
ohioflhs's Avatar
ohioflhs
I think the Stabil is your problem. That stuff breaks down. The few months of winter here in Ohio is short enough to avoid using it. Never used it , never needed to.
