Fuel gauge stuck on full
Subscribe
Mar 26, 2012 | 04:11 PM
Hi everyone, I picked up a nice set of Screamin Eagle spun aluminum gauges from a friend for my 06 FLHX recently but the fuel gauge always reads full for some reason. I know it was working previously and if I hook up my old gauge it still shows the correct amount of fuel. Any ideas of what could cause this? Could it be that the gauges came off of a fuel injected bike and mine has a carb? I'm really at a loss here and would appreciate any insight I can get to fix this problem.
Reply 0
Mar 26, 2012 | 04:12 PM
different type of sender.
the injected sender is Harley-Davidson #75279-06
and i have no idea if the wiring harness would need to be changed as well, and if it would even mount in your tank with out the EFI fuel pump which it mounts to.
you could probably get the gauge itself for less and easier
Mike
Reply 0
Mar 26, 2012 | 04:23 PM
So basically that gauge will not work with a carbed bike? Do you know if the spun gauges are available for a carbed bike?
Reply 0
Mar 26, 2012 | 04:30 PM
Wouldn't it be Sa-Weeet...
...if your gauge read full all the time cause your tank was really always full?
Oops, did I say that out loud?
I guess you could check the HD web site and see if spun aluminum faced gauges are available for your motorcycle.
If not, maybe the parts guy or service guy at your friendly, neighborhood Harley dealer would know what you could do.
If not, check out and independent repair shop.
Good luck!
GSF
Reply 0
Mar 26, 2012 | 04:32 PM
see if you can get a wiring diagram for both bikes. It is possible you just need to wire your unit differently. Shot in the dark but worth a try fuel senders are usually pretty basic.
Reply 0
Mar 26, 2012 | 04:35 PM
I called the dealer and they had no idea. I do have a wiring diagram for my bike, does anyone happen to have one available for an 08 touring bike by chance? I can't imagine they are that different but I'll try anything at this point, I really like these gauges and want to keep them on there.
Reply 0
Mar 26, 2012 | 04:44 PM
I think I found the problem, there are two sets of these gauges - one for 04-07 and one for 08-later. I'm guessing I just have to swap mine for the 04-07 and the problem will resolve itself. Well...Anyone looking for a like new spun aluminum fuel gauge for an 08-later touring bike? hehe
Reply 0
Mar 26, 2012 | 05:05 PM
I think 08 went to letting the ECM monitor fuel consumption and report it in the LCD display on the Speedo. You should still check a wiring diagram for an 08.
Reply 0
Explore
Subscribe
