Hogtunes Install
Old Jan 1, 2007 | 12:48 PM
rjmac53's Avatar
rjmac53
Default Hogtunes Install
I have an 07 Street Glide. I bought the 'tunes speakers and am in the install process. I got the outer fairing off with no problem, but believe it or not I cant unsnap the spade connectorsfrom the speakers.
Either I ama moron (very possible)nd there is a trick? I thought I did the hard part taking the outer fairing off. Can you guys help a wrench challenged do it yourselfer?
Old Jan 1, 2007 | 12:56 PM
Terry TK's Avatar
Terry TK
Big Kahuna HDF Member
Default RE: Hogtunes Install
They are really tight. I did an install on a friends bike and had to use two pair of needle nose pliars. Be very careful not to damage anything but you'll have to go for it.
Old Jan 1, 2007 | 12:57 PM
Sharknose's Avatar
Sharknose
ORIGINAL: rjmac53
Not sure what you mean by "unsnap". The spade connectors slide over the speaker terminals--TIGHTLY. My "trick" is to use a flat blade screwdriver to pry the spade lug off.
Old Jan 1, 2007 | 01:08 PM
HD Renegade's Avatar
HD Renegade
They were pretty tight on mine when i did it too. I was jusr careful with them and wiggled them until I got them to come apart. take your time, I am sure you will get it done.
Bob
Old Jan 1, 2007 | 02:37 PM
maineultraclassic's Avatar
maineultraclassic
Mine were super tight also, I used a pair of needlenose pliers to pull them off. Be careful, is you are pulling hard and they give way........$hit can happen fast.
Steve
Old Jan 1, 2007 | 08:42 PM
Harleypaw's Avatar
Harleypaw
Your pulling them off a set of speakers that aren't worth having anyway, so if you damage the stock set, so what, once you get the Hogtunes installed the old stocks will end up in the garbage anyway
Old Jan 1, 2007 | 09:22 PM
PEZ's Avatar
PEZ
Hey
I usually support the black cardboard "plate" the connectors are on with my left thumb and forefinger. Then I "loop" the wire around my right index finger and givera YANK. Ive done it enough times I know it works everytime
Later eh--and HAPPY NEW YEAR. Im goin on holidays Weds to Sunday. Will start posting after my liver floats back to where it once was
PEZ
Old Jan 1, 2007 | 11:47 PM
JeffSG's Avatar
JeffSG
Good information! That is why I have said time and time again this is a huge resource of information for DIYs.
Ride safe,
Old Jan 2, 2007 | 01:28 AM
Sharknose's Avatar
Sharknose
ORIGINAL: JeffSG
Ride safe,
It's not often the guy who makes the product in question is available to offer tech support on a forum like this.
Dtroy
Audio Systems
Apr 16, 2017 05:44 PM
Bullitt59
Feb 8, 2013 03:07 PM
MrCarver
May 11, 2011 10:10 PM
alfalf
May 4, 2007 11:18 PM
Kahuna
Jun 11, 2006 02:32 AM
