2007 RKC Need advice Please
Old Jun 9, 2012 | 09:19 AM
cpudoc's Avatar
cpudoc
Default 2007 RKC Need advice Please
I have a 2007 RKC. I put Screaming eagle slip on"s on it yesterday. I also have the "fullsac" dual conversion. So I am running true duals and SE slip ons. I was gonna stop there but a Screaming Eagle Big Breather just became available for $75 bucks. I love the look of it and will buy it. If I havent had any ECU programing done with the exhaust mods, and install the SE big breather what will be the effect on the engine. I just can not afford to get the Steelership to do the download/Dyno as of yet. Will it hurt the engine?
Thanks
BTW: I know about the ad on fuel mgmt systems. I just cant afford them as of yet
Old Jun 9, 2012 | 09:22 AM
2011Deluxe's Avatar
2011Deluxe
You will be fine 2007 and up dont have to have the download.
Old Jun 9, 2012 | 10:22 AM
mkguitar's Avatar
mkguitar
alternatives:
Ness Big Sucker on ebay from easternpc
about $120.
avantages:
easier install ( don't have to remove throttle body brace)
chrome backing plate ( which complements the black and chrome motor)
washable, reusable oiled filter media
Nightrider.com XIEDS ( about $130)
give a slightly richer mixture under most riding circumstances.
plug in install takes minutes & done.
These are the products I use on my 09 to good result and at good price
mike
Old Jun 9, 2012 | 02:44 PM
cpudoc's Avatar
cpudoc
Bump. Anybody else?
Old Jun 9, 2012 | 08:02 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
my 07 ran hot lean and pinged stock,unridable with slip-ons and ac,tried xieds they were an improvement but still would get hot then ping,pcv fuelmoto map and runs like it should,never relized how lean it was surging stumbling heat,all went away.
Old Jun 9, 2012 | 08:15 PM
Thickraybans's Avatar
Thickraybans
I would save until you can get a good EFI tuner, preferably one with an auto tune feature. Even a totally stock late model bikes performance can be improved a lot with a good tune.
Old Jun 11, 2012 | 02:41 PM
cpudoc's Avatar
cpudoc
Ok I put the Ac and slip ons on. Road 200 miles and no pings, not one pop, and Great gas milage. The bike popped before I did the ac and mufflers. I took it to the dealer they search. It never had "the download" The mechanic took it out and said " dont change anything" it is running perfect. He said the the PO may have had someting done to it before trading it. I am very happy with it and apparently got luckey with free SE slipons and SE heavy breather for 75 bucks!
Old Jun 11, 2012 | 03:28 PM
TKDKurt's Avatar
TKDKurt
I'm no mechanic, nor do I play on TV, but what I have heard repeatedly is that if you change the AC you HAVE to have the download or have a tuner. Otherwise you're bike will run WAY too lean with the increased airflow and can be damaged by the resulting heat.
jimwebber
Jun 8, 2010 11:16 AM
NJOYINIT
May 13, 2008 07:38 PM
12345tb
Exhaust System Topics
Apr 22, 2008 03:04 PM
Bikerdoc
Screamin Eagle CVO Models
Oct 27, 2007 11:16 AM
cjackson
Feb 19, 2007 11:59 AM
