head buffeting
Old Jul 2, 2012 | 09:16 PM
  #41
flyburch's Avatar
flyburch
i had an 06 ultra and a 09 cvo ultra neither buffeted this bad. they both have the vents so ill try that. LOL someone posted about holding your left arm across your chest to notice the difference.. I can ride like that all the time i guess.. Im kidding and know it was just to show how much wind is coming from under the bat wing.
Old Jul 2, 2012 | 09:22 PM
  #42
porkchopsd's Avatar
porkchopsd
Originally Posted by flyburch
how did the klock works fix the buffet from the bottom of the bat wing
han't really noticed buffeting from the bottom of the fairing, I wear a full face and with the KW I can leave the face shield up and I can see fine, in a couple of weeks I am putting fairing lowers on and the lower fairing vents and that should make the ride that much better.
Old Jul 2, 2012 | 11:16 PM
  #43
flyburch's Avatar
flyburch
I'm going tomorrow get the vents see what happens
Old Jul 3, 2012 | 11:54 AM
  #44
leadermc's Avatar
leadermc
Former Sponsor
An easy way to cut down the updrafts that cause buffeting - and they are removable - is the rain guards (no temperature restriction on ours): http://www.leadermotorcycle.com/harl...n-rain-guards/
Old Jul 5, 2012 | 11:48 AM
  #45
Deuuuce's Avatar
Deuuuce
Originally Posted by Iceman24
Becauuuuuuuuuuuuuuuse this doesn't solve the problem (Einstein). Even w/FF helmet + taller w/s it only helps w/air from "above" the fairing/shield & does nothing to prevent "lower" airflow which pretty much most of the problem. Also...wearing FF helmet isn't even a factor b/c buffeting shakes your "head" - including whatever you're wearing (helmet, no helmet, etc...) so it's not a possible solution at all...
Now, FWIW, here's what I did to solve the dreaded buffeting cycle; (1) taller shield (KW 8.5"), (2) fairing wings (HD's set that opens), (3) HD fork baffle & (4) vented lower fairing. Sure adding these "four" upgrades was $pendy, but it worked & you can't put a price on riding comfort/safety.
Apparently it is a factor based on those reporting that changing helmets makes a difference.
I have a well-designed FF (Shoei) and a 10" shield and only get buffeting in extreme crosswinds.
Perhaps because I have 13" apes, I have no issue at all.
Originally Posted by zoozoo
All of that is correct but many buy the SG for the cool factor and they do look cool right off the show room floor. Great for putting around town (bar hopper). Then you get on the road for a long trip and dam your eyeballs start to shake, ratttle, and roll. The only way to solve the problem is do as you say but for many that will take away the cool factor. This is the problem facing alot of SG owners.
When I was younger I would rather look cool than be safe and comfortable. As I'm getting older that has reversed.
Far as I can tell the only difference vs. the EG is running lights and taller shield in terms of air flow.
Originally Posted by racklefratz
You just stirring the pot, or what?
Post after post here confirms the fact that "buffeting" comes from UNDER the batwing, not over it, and you suggest a FF & "taller shield"? C'mon.
And get out some day and ride in 107+ degree weather with your FF helmet all visored-up and report back on how great it is with sweat dripping down your face.
I'm 5'11", and an 8" recurve shield, fairing air deflectors, fork baffle, and fork mounted deflectors fixed it for me. Screw the "cool factor" - if I can't enjoy the ride, that ain't "cool".
Done it. I ride with the visor up much of the time anyway. That's too hot for an enjoyable ride anyway. Do many 3/4 and 1/2 helmets have vents directing airflow over the scalp? Curious about that.
Originally Posted by checkers
You are exactly correct. SG's ridden as stock look great and do many things well, but not the overall choice for "touring"
Windshield and taller shocks were the 2 easy changes. Seat choice and luggage is personal preference (and for the passenger).
Old Jul 8, 2012 | 01:26 PM
  #46
racklefratz's Avatar
racklefratz
I recently spent nearly $1K for a new Schuberth C3 with optional communications installed (SRC), and it's a dandy, best fitting helmet I've ever owned. But even with it open, temps lately here have been way too hot to wear it. It'll have to wait till it cools off.
Only helmet I own that I can stand to wear, now that it's getting over 100 deg outside, is my Scorpion EXO-100. It has a built-in sun visor that's sort of nice, and it does have some air vents under the front of the helmet that are supposed to do that scalp venting thing, but they're not enough (now that I've blocked all the buffeting )- not much cooling effect by venting 100+ deg air over your scalp. I actually hate wearing a helmet - any helmet.
Old Jul 8, 2012 | 02:05 PM
  #47
racklefratz
can you except for the shield list the rest of the things you have and where you got them thanks.. oh maybe a picture not necessary but if you have one that would be great
OK, here ya go - **MY** solution to making my 2012 an enjoyable ride:
The left arrow points to what I found to be the most effective part in my process of eliminating air turbulence coming from below the batwing. I found these chrome fork-mounted wind deflectors on eBAY, and they installed in minutes. Not sure what the spots on the left one are in the image, probably bugs or lighting anomolies, but these are nice quality parts, good chrome, and were the only ones I found that enclose the turn signals and extend all the way up to the batwing. Others I saw did not. IMO, they nicely compliment my chrome front end.
Middle arrow points to the HD "Chrome Front Air Baffle", pn 58520-79TC. This is probably one of the least effective parts for air deflection, but it's also the cheapest. I wanted to cover all the bases.
Right arrow points to HD fairing air deflectors. They're available in dark or light smoke color, and fixed or adjustable. Mine are HD pn 58166-08A. There are a lot of imitators available, but you get what you pay for. My "Freedom Wings" wound up in the garbage.
With these parts on my bike, I now ride with some breeze, but no buffeting; there's essentially no air turbulence reaching me from under the fairing. Life is good.
Old Jul 8, 2012 | 03:24 PM
  #48
Glide'nTony's Avatar
Glide'nTony
I just installed faring air deflectors this morning. Dark tint, $109.95 at the stealership. Took about 10 minutes to get them on, went for a ride and the buffeting was cut down 65-70%. Much more comfortable at 70 and I don't have to worry about the buffeting ripping my Oakleys off my face. Gonna measure myself for a LRS shield tonight.
Old Jul 8, 2012 | 04:06 PM
  #49
rufasim's Avatar
rufasim
I have the lrs 7" ultreawith the flip top, as well as the fairing deflectors. I still get a little bit of buffeting but it comes up by my legs. If I spread my legs off the tank at 75, the buffeting is worse. Still bearable, but worse. Last night I thought I would do an experiment. Up on the highway I went. Got to about 75 and felt around for the wind. It hit me half way up my 1/2 helmet from over the windshield, no problem there. Put my hand over the tank, nothing there. Deflectors doing there job. then I started feeling for the wind was coming from. Sure enough, right by my knees. If I put on lowers or the rain shield I am sure it would eliminate all wind all together. If I wanted that I would take either my truck or my car. this is a motorcycle and I am supposed to feel some wind in the face. The glasses bounce around a bit, because they are in the wind, where they are supposed to be. Dont't bother my visiom at all.
I am sure if I put on my ff the buffeting would be worse so I will just wear my half helmet and a smile.
Old Aug 27, 2012 | 05:29 PM
  #50
sergel's Avatar
sergel
Funny, I never tought of buffetting until I started my preparation for my vacation and got a nice 3/4 helmet (Nolan N43...) I still have the factory shield on my Classic and look through (although I am starting to think I have enough of looking at the road through buggs and stuff...). So, as soon as I put the new helmet on and closed the face shield...this thing pounded on me like some one was hitting the helmet with a wodden mallet...
Now, with a half helmet, all is good... (i get some wind in my face but hey... its a motorcycle...) But this buffeting effect of the closed helmet is enough to drive me crazy. I got this helmet for bad weather driving, but kind of like the closed ears and clear view for long rides. The visor on this thing is so clear its like wearing nothing at all in your face...
I guess its comming from the bottom, I thought initially it was comming from the top, but if I put my arm in front of me it almost all goes away. its like the wind catches in the face shield like under a bell if that makes any sense...
I am going to try the fork deflectors for sure... cheep compared to anything else, I already have the HD fairing deflectors and would not live without them. Love em when its real hot, I call them my air conditionning...
Air is all right, dirty air is annoying as hell...
