Alarm Install
http://www.harley-davidson.com/en_US...ts/-J04082.pdf
NOTE: in some cases you will not be able to start the motorcycle because the security system is in disabled mode until it is married to the ECM.
The marrying part is the hard part if doing it "by hand".
Once you read the instructions.... decide if 2.5 hours labor is out of line
Are you ready for this?
Once you have the parts installed and wires plugged in, you have to marry the TSSM to your bike.
Tssm Marriage
1 Set Run switch to Run
2 Turn Ignition key On-Off-On-Off-On-Off-On and then toggle
the Left Turn Signal switch twice.
3 Turn Ignition key Off-On Verify the Check Engine lamp and Security Lamp illuminate
briefly and then turn off Security lamp will not illuminate on non-security
(TSM) Twin Cam models.
4 Attempt normal start one time. Engine starts and stalls immediately. check engine
lamp stays on. Password has not been learned and sets trouble code P1009, thus stopping fuel
flow.
5 Wait 10 seconds Security Lamp remains lit for V-Rod and TC88 with TSSM. Lamp will not be on for TC88 TSM models. ECM enters Password Learning mode for 10 minutes.
Do Not cycle the ignition or disrupt power.
6 Wait until Security Lamp turns off or a minimum of 10 minutes has passed.
7 Quickly (within 2 seconds) turn Ignition key OFF-ON Security Lamp remains lit for V-Rod and TC88 with TSSM. Lamp will not be on for TC88 TSM models.
8 Wait until Security Lamp turns off or a minimum of 10 minutes has passed. Password Learning mode for 10 minutes. Do Not cycle the
9 Quickly (within 2 seconds) turn Ignition key OFF-ON Security Lamp remains lit for V-Rod and TC88 with TSSM. Lamp will not be on for TC88 TSM models.
10 Wait until Security Lamp turns off or a minimum of 10 minutes has passed. Password Learning mode for 10 minutes. Do Not cycle the ignition or disrupt power.
11 Quickly (within 2 seconds) turn Ignition key OFF-ON Security Lamp light and then turn off. Lamp will not be on for TC88 TSM models.
12 Turn Ignition switch OFF. Wait 15 seconds. Turn Ignition switch ON and start engine to confirm the Password Learn Procedure is successful. Engine will start and remain running
If engine immediately stalls and fails to restart the Password Learning mode was not successful. Start over at step 1.
Then, once you get this far, you will have to take your bike and fob to the dealer to get programmed to work together. YOU STILL HAVE TO PAY THE DEALER.
Totally understand. Just wanted to save you from what a friend went through trying to do it himself.
He ended up paying the dealer to do it............ after he worked on it for 5 hours.
He still has a wrench stuck in the drywall of his garage, where it stuck when he threw it in anger. He left it there as a reminder to not get in over his head on DIY projects
The fobs have to be programmed by the HD dealer.
