Bagger wobble exposed!
Old Jul 30, 2012 | 07:52 AM
  #201
grbrown's Avatar
grbrown
Come on chaps, put away the handbags! As the OP I am disappointed my thread has prompted so little discussion on this subject, although I have had a lot of requests for the magic bullet, via this thread as well as by PM.
So for the benefit of those of you who do not do cryptic crosswords and have not yet solved the clues given to date, allow me to remove all doubts and say the product I use and recommend is True-Track.
I would also like to assure you all that I have no links with True-Track, except as a happy customer and that I have owned and used their products, on both Touring and Dyna bikes, since before they became sponsors of HDF.
Old Jul 30, 2012 | 08:24 AM
  #202
tlr's Avatar
tlr
Originally Posted by grbrown
Pleased to oblige! I think I'm up to date with replying to requests.
Great post. I have a 2012 SG. Please send me the info I need as well. Very much appreciate it.
Old Jul 30, 2012 | 08:31 AM
  #203
grbrown's Avatar
grbrown
Cool
Hi Ted, please read post #201 above. Thanks!
Old Jul 30, 2012 | 09:13 AM
  #204
tlr's Avatar
tlr
My bad just did. Made it thru a lot of the thread, but not far enough. Thanks for the info.
Old Jul 30, 2012 | 01:39 PM
  #205
cotter pin's Avatar
cotter pin
This is a great write-up. Thanks for the clear and concise information. Nicely done!
Old Jul 30, 2012 | 03:53 PM
  #206
sftdyna's Avatar
sftdyna
will the progressive touring link work as well? there on ebay for less then half of the true tracks so i was wondering if anyone is up on this unit. thanks
Old Aug 1, 2012 | 01:07 AM
  #207
northeastconfederate's Avatar
I'll chime in here and share my experience with the wobble: I first experienced it after entering an exit ramp kind of "hot", at about 55-60. This is a ramp with which I'm intimately familiar, it's part of my commute. Take it at that speed in my 28 year old Benz (300SD - a luxury tourer, NOT a sports car) no problem; my Road King shohld be able to handle it NO PROBLEM. Well, there's a dip partway through, not all that noticable in the car. I'm relaxed, I know this road. Let me tell you, I hit that dip & had the chit scared outta me when my bike wobbled! Thought it was me. Tried it again next time, paying close attention to my riding technique. It happened again! Same thing on a different sweeping highway curve. I can take a different line through that curve, avoid the dip & avoid the wobble. It's real, there's NO doubt about that. I do ride my bike harder than many ride a bagger, no doubt about that either, but no harder than some. I am no pro AMA rider and J have a buddy that rides a Gold Wing like it's a sport bike, and that barge is bigger & heavier than my road King. So don't tell me a bagger isn't meant to, or shouldn't be ridden hard.
I just upgraded the shocks with Ohlins 3-3's from Howard, will be rebuilding the forks with some upgraded components and will be adding a brace. I have ~80,000 miles on mine & am very famikiar with this wobble, having experienced it numerous times throughout those miles. Once I learned what it was it makesbperfect sense. Ignorance is bliss, but it is high time to do something about it!
Old Aug 9, 2012 | 09:11 PM
  #208
ratdoc's Avatar
ratdoc
Hope you teach for a living, Graham. Great explanation. Thanks.
Old Aug 10, 2012 | 02:00 PM
  #209
zeus33's Avatar
zeus33
Big Kahuna HDF Member
I have been almost bucked off many times due to the infamous bagger wobble. I'd like to get a brace to fix it. Problem is I have an EZ-Up center stand that's using the spot where most of the braces mount.
Can anyone recommend a brace that doesn't mount on the cross piece under the engine? ONe that works well.
I have an '08 road glide.
Old Aug 10, 2012 | 03:33 PM
  #210
Rockymtnglide's Avatar
Rockymtnglide
Great discussion and I certainly appreciate your effort and opinions. I have a fast sweeper with uneven pavement in Colorado and get wobble to some degree every time I go that way. Have checked alignment but haven't replaced or added any components.
07 Streetglide...Please add me to PM.
