Bagger wobble exposed!
As I described in my first post, the mounts serve two purposes, one to mitigate the effects of engine-speed vibration or shake, the other to dampen the higher frequencies. All reciprocating engines generate harmonic frequencies, at multiples of engine speed, and rubber serves well to help tame them.
Read the Six degrees of freedom link, where you will see, but for one flaw, that the original Harley system addresses all the articulation you refer to. It is an elegant design!
Back in 2005 the British magazine 'Bike' conducted an extensive test of all the sports bikes of the day, including Ducatis and the top Jap models. The Buell Firebolt was voted best handling! So the Harley system can work alongside the very best out there. Of course that doesn't detract from an alternative approach, so retire soon.....
I've been riding and refining my own bike for 22 years now! It's coming along fine. Not perfect, but better, with a little help from you!
I installed a Tru Track on my '08 Dyna with only a few thousand miles on it on a rainy day and didn't take the bike out until a few days later , forgetting that I had installed the stablizer. I immediatley noticed a difference in handling like I was on a rail , the bike handled great. Now I added a '10 RK to the stable and installed a TT on it also with just a few thousand miles on it but didn't notice any difference at all.
Also, just more info .. I lost a friend recently going a documented 45mph when his '02 RK went into a wobble on a corner and he lost it. Three witnesses!
RIP Lumpy
RIP Lumpy
- Bagger Brace
- Custom Cycle Engineering Triple Tree Pinch Top Bolt Plate
- Progressive Mono-Tubes front/940 rear shocks
- Both tires under 500 miles properly inflated
I have to disagree! A stabilizer will tighten up the steering of your bike and improve the riding experience at all speeds. If you fit one you will notice the improvement before you get into top gear. If you never ride fast you will still benefit, as your bike will be more responsive and steer more accurately. We can ALL win!
HD Touring bikes can be made to corner better with more stability, but it's only slightly better than polishing a turd (as far cornering goes when compared to other bikes)
I love my touring bike, but I fully know what it is, and what is isn't.
I have never experienced the wobble, probably because I haven't pushed it hard enough. As far as tracking, the bike, at least mine, is predictable and goes where I point it. With the gear I have on it for long distance touring, I'd probably scrape the boards to the point of levering the bike if I tried to corner hard.
Like I said, I'll end up getting the proper tool for the job. Probably a sportster, solid mounted. It's a great starting platform and won't take much if anything to run circles around a modded tourer.
The occasions when our attention is most emphatically grabbed is at speed, for example in a fast bend and when hitting a bad patch of road, which upsets the balance of the bike. That is when the 'squash' occurs at its greatest and misalignment of the rear wheel is momentarily at its worst.
