Bagger wobble exposed!
Old Feb 9, 2020 | 04:11 PM
  #711
Y2K's Avatar
Y2K
One thing I learned after doing considerable mileage and I have owned 3 Electra Glides at this point is that tires are a huge factor.
Better tires make a lot of difference,the stock tires pretty much suck for handling and are far too prone to speed wobble.
A couple of my buddies couldn't figure out why I was leaving them in the dust going over Donner Pass,they both got wobbles as I pulled away still increasing my speed in the big sweepers.
I teased them and just said I'm a better rider that's all, truth is they both had OEM Dungflop tires and I had Metzler 888's.
I ran the Metz 880's for quite a while and they handled great but were disappointing in the wear mileage so I ran some Dumlop Elite III's for a couple rounds.
They were decent handling and wear great but not as confidence inspiring as the Metzlers,then came the new 888's so I tried them.
Very pleased,handle like the 880's and wear nearly as well as the Dunlop E III's.
At any rate very little wobble issues with any of them once I moved away from the OEM tires.
Old Feb 9, 2020 | 04:33 PM
  #712
memphisharley's Avatar
memphisharley
Originally Posted by Shrek1966
I have a 2019 streetglide, 5200 miles. Input a stage 4. I have felt the wobble 3 times. The last 2 was pretty bad. Number 3 was on a straight shot when I hit 100-105. All,of this is on private property 1 mile long.
My question is "has any felt this on a new bike" ?
they all do that
Old Feb 10, 2020 | 08:50 AM
  #713
grbrown's Avatar
grbrown
Thumbs up
Originally Posted by HDREDRAT
Excellent write up.. they wobble.. anyone who says they dont... isn't very aggressive at all. It doesn't take much to upset the swingarm bushings at speed.. I experience it often on my 2015 RGS. Just finished installing true-track front and rear. Hoping for a more confident bike come springtime. And since I run the "Alloy Art Stabilizer already, and it didn't stop the wobble at all, I'm inclined to think that there is not only a lateral action where the swingarm meets the chassis...but a "racking action" as well.. stabilizing lateral movement of the motor at the top AND bottom, front AND rear would seem to be the only effective solution...and soon I will know! Thanks again...
Do let us know how things work out with your new set-up. It is possible your Alloy-Art kit will not work well with the T-T, as they are both supposed to solve the same problem - in their slightly different ways.
Old Jul 15, 2020 | 01:47 PM
  #714
Keithgordon092's Avatar
Keithgordon092
5th Gear
grbrown,
I sent you a contact request as I would like to ask you a Private question about my 2019 Road Glide and the True Track system, it is clear after reading this thread you may be the one to clear the confusion I have. If you please add me to your contacts so I can send you a quick message. I need some sound advice before I purchase this kit. Please.
thank you,
keithgordon092
i am new to this forum and have tried to send you a direct message
Old Jul 15, 2020 | 02:18 PM
  #715
Keithgordon092
5th Gear
Default 2019 Road glide
grbrown,
I think this may be the only way to contact you so I am going to post my question here and see if you get it and can solve my question. I live in Jacksonville,Florida and have been riding many years and am comfortable in many riding conditions. I am however new to my 2019 Road Glide. The area I ride in is primarily Interstate riding and while I have a big touring bike I am finding I am getting blown around on the interstate with the wind conditions here and the semi-trucks that travel through my area. I do not have a lot of twists and turns I am concerned about just 75-80 mph interstate travel. I have about 4,000 miles on this bike so it is not new to me and am comfortable on it. I called True track and of got the “yes it help with stability speech” but of course they are trying to sell me a kit. This is a new product for this model and there are no reviews that I can find about this product anywhere on the internet. As I said I read your initial thread and it is clear you understand the Harley Davidson frame. In your opinion will I benefit from this product if I apply it under the described conditions I listed. Thank you for any help you can offer.
Old Jul 15, 2020 | 02:21 PM
  #716
V-Twins & Bowties's Avatar
V-Twins & Bowties
Need more posts to access features. Half dozen or more I believe.
Welcome to the Forums, have some enjoyment/ entertainment.
Old Jul 15, 2020 | 02:27 PM
  #717
Keithgordon092
5th Gear
Default Thank You
Thank you, this was my first time here I am trying to find more info on this system
Old Jul 16, 2020 | 05:51 AM
  #718
grbrown's Avatar
grbrown
Wink
Originally Posted by Keithgordon092
grbrown,
Keith, I don't have a recent model like yours, so don't have much experience of riding one. However you ask a simple question and my simple answer is Yes, I believe you and your bike will benefit.
I still have my Glide with a T-T kit on it and for many years rode a Dyna with one. I also still have my rubber mount Sportster and Buell, both of which came with a full set of stabilizers from the factory. A full set of stabilizers is a good thing! I have commented in the past that after fitting the kit to my Dyna that bike was better handling as soon as I set off on it, for the first time. It steered straighter, responded better to the steering, went around corners better, etc, the improvements were very distinct and obvious. I suspect you will have a similar experience.
Hope that helps!
Old Jul 16, 2020 | 06:04 AM
  #719
grbrown's Avatar
grbrown
Talking
grbrown,
thank you,
keithgordon092
'Tis done!
Old Jul 16, 2020 | 06:49 AM
  #720
motolocopat's Avatar
motolocopat
grbrown,
I have both a 2013 Streetglide and a 2015 Road Glide and for me the difference is night and day. The SG with its fork mounted fairing & spindly front forks did wobble enough at certain time like passing a truck and coming back across the paint stripe or strong cross winds that ot prompted me to buy the RG. The 2014+ bikes all have much beefier front forks and that along with RG frame mounted fairing seems to have eliminated the issue. On the 4th I rode over to Denver and then up into the Rockies. Down then Slab I ran 100-105 for 30 minutes or so and had zero issues. Pushed it up to 115-120 for 5-10 minutes and had no wobbling but it was starting to get out of its league a bit, or maybe mine.
Id be spending money on some suspension upgrades befoe a TT or similar
