Auto Tune for Touring models
I now have a Power Vision and have a rich tune stored on it, but I can't toggle like you guys can with the PCV. I must stop the engine and flash the tune, a 30-sec. operation. Since installing the PV I haven't used the rich tune even once, except once when I loaded it by mistake. I noticed it quickly because my gas mileage suffered considerably. Other than doing it this way I'm not sure why you'd want to turn off AT, that assuming the base map has been "accepted" (accept trims option) repeatedly to get it close to the tune established by AT.
The "hardware switch" (DynoJet's terminology) that you use for toggling a PCV must be free of any 12V current and must be only a continuity switch. The stock ACC switch on my bike is powered by the P&A fuse and I can disable any 12V from the switch by pulling that fuse. No other item is powered by that fuse on an '07, but later models use it for other things, so check your electrical diagrams before pulling the P&A fuse. This is the way it would be done on an '07:
If you don't pull the fuse you can simply cut or otherwise disable the OR wire from the 12V source. That way the switch will be removed from the 12V grid and your other accessories will continue to work.
An open switch (normally off) toggles open-loop while closed (normally on) it toggles closed-loop (AT or learning mode). I use my stock ACC switch for heated clothes, so I installed another one without any power connected. The LED in the switch will not work unless you rig a relay, which I did on mine. Here's the way I did it:
Depending on how you wire the relay you can rig the LED to come on for AT (pins 2 & 6 as in the diagram) or base-map mode (pins 4 & 6 instead), but since AT was normal for me I wanted the light to come on as a warning that it was not in its normal state. Normal was AT for me, so I had the LED coming on when in base-map mode.
With this relay you can use the other side of the relay for some other item to work with the switch, like maybe an oil-cooler fan.
As for adding another ACC switch, that would be my choice even if I didn't already have some use for the original like I do now. Leaving the stock ACC switch and harnesses unmolested is better than hacking on the wiring, IMO, and adding another switch is fairly easy even though you'll have to run the two wires under the tank. My bike had three extra switch slots originally but only one was available after I added a cruise control and a jury-rigged garage-door opener. Now my panel is full.
