Something ain't right
Old Aug 16, 2012 | 05:49 PM
mmcbeat's Avatar
mmcbeat
Default Something ain't right
I went for a ride today - 100+ degrees. I got stuck at a stop light and my scooter really sounded bad. New bike, less than 1000 miles. Then I realized that the back cylinder had shut down at idle because of the heat. First time this has happened to me. Life is good!
Old Aug 16, 2012 | 06:02 PM
mkguitar's Avatar
mkguitar
the owner's manual explains it all.
and the important stuff like tire pressure too.
( we had a guy post on here once he was gonna "sue H-D 'cause his bike wobbled all over the place."...tire pressure: 25 pounds)
enjoy the new ride, enjoy it more by knowing the whys and wherefores of what it is doing.
Mike
Old Aug 16, 2012 | 06:24 PM
MontyD's Avatar
MontyD
What's the cause?
Old Aug 16, 2012 | 07:09 PM
mmcbeat's Avatar
mmcbeat
Mike
Yeah, I read the manual and was aware that the rear cylinder shuts down when it gets hot. Thing is, this was the 1st time it happened to me and it was a little disconcerning.
Old Aug 16, 2012 | 07:12 PM
Pagan48's Avatar
Pagan48
HaHa - Yeah, 1st time it happened to me I thought something was wrong too. Although there are plenty of critics on this forum I am a fan of the EITMS. Here in Florida it comes on all the time.
Old Aug 16, 2012 | 07:21 PM
harleyflyboy's Avatar
harleyflyboy
Here goes the argument. I installed Xieds on my '09 Ultra soon after I got it. That summer we had over 60 days of 100 + temps. And have only had the cylinder cut out a couple of times since then.. it really does work. It seems to richen the mixture just enough to keep the cylinder below the critical temp.
Old Aug 16, 2012 | 07:22 PM
bentryder's Avatar
bentryder
i didnt like it.....shut mine off on the first day.....hasnt been on since....
Old Aug 16, 2012 | 07:30 PM
mkguitar's Avatar
mkguitar
I use mine manually ALL the time ( roll the grip forward and hold while stopped at a light).
This pumps air through the cylinder and the air removes heat. a cooler motor will last longer and the rider will be more comfortable
To turn it off makes no sense
it gets warmish here in PHX
Mike
Old Aug 16, 2012 | 07:37 PM
whiskyls1's Avatar
whiskyls1
Mike
I heard this from a friend and when I inquired about it further was told that you cannot operate it manually. It is either on or off.
Rolling the throttle forward just changes the setting from on to off.
Anyone else have any insight on this?
Old Aug 16, 2012 | 07:42 PM
Tedjay's Avatar
Tedjay
Originally Posted by MontyD
What's the cause?
The cause is the Engine Idle Temperature Management System (EITMS). It's designed to do that. The manual explains how it works and under what conditions it shuts off the rear cylinder.
