LOADING electraglide WITH NO TAILGATE?
Old Aug 30, 2012 | 09:37 PM
  #31
jmorganroadglide's Avatar
jmorganroadglide
Big Kahuna HDF Member
Upon further review, if you will goggle "trailer hitch extender", your problem will be solved.
Old Aug 30, 2012 | 09:43 PM
  #32
loanrider's Avatar
loanrider
Trailer hitch extender
http://www.northerntool.com/shop/too...2405_200442405
Old Aug 31, 2012 | 10:09 PM
  #33
marines267's Avatar
marines267
Originally Posted by jvislax32
I have a huge dilemma. I have a 6ft bed truckf150 i need to haul a electraglide from naples fl to asheville nc im taking a 14ft boat becuase ill be down there in naples for a fishing trip for a week. With a jacknife v tailgate down hits the bow holder. how can i haul the electra glide with the tailgate off?4x8 plywood? 2x6?
Here's a thought why don't you ask a friend to go with you and let him ride the bike back. Instead of taken the risk of putting it in the back of the 150
Old Aug 31, 2012 | 10:45 PM
  #34
Eshaw301's Avatar
Eshaw301
Default Use a jack like I did!!!
had the same dellima about 4 years ago...had to tow a trailer and haul a bike in a 94 silverado shortbed...what i did was this...and it worked excellent...load the bike into the bed with tailgate on, then use a jack to jack up the bike so that the rear wheel is off the bed and its not touching...jack should be placed towards the backend of the bed and of course under frame of bike...strap the jack down to the points on the bed so that its secure and doesnt move...then strap the bike down while its being supported by the jack...remove tailgate, hook up trailer and go! P.S. Be sure to check your load every 50 miles or so just to make sure all is well. this worked for me towing a car and my bike WITH a rollaway toolbox back there in the bed with it, from Groton CT. to Phenix City, AL...Good luck.
Old Aug 31, 2012 | 10:54 PM
  #35
skratch's Avatar
skratch
so we are looking at a distance of about 6ft 7 inches? and if i can angle it ,im going to measure the length of usable distance brb also its a 2001 electraglide with only 15,000 miles what a waste but gain for me they need to be ridden not parked
hd specs the length at 98 inches.....
Old Aug 31, 2012 | 11:11 PM
  #36
Devo6684's Avatar
Devo6684
Originally Posted by loanrider
This seems to be a simple and cost effective solution.
I do have a topic related question- I have never loaded a bike in a pickup. I too have a Silverado with a 6' bed and contemplated loading the bike with a ramp and winch, however, will the tailgate support a 900# bike?
Good luck with your dilemma and be safe.
Old Aug 31, 2012 | 11:13 PM
  #37
TXCOMMISH's Avatar
TXCOMMISH
Can't believe no one has suggested to put the bike in the boat. Problem solved.
Old Aug 31, 2012 | 11:20 PM
  #38
TXCOMMISH's Avatar
TXCOMMISH
Double post,, sorry.
Old Aug 31, 2012 | 11:29 PM
  #39
Eagle Custom's Avatar
Eagle Custom
Extended hitch I pulled a 3 horse trailer from Cal. to Mo. loaded with household items using a extended hitch becouse the truck had a 10.5' camper in the bed and it worked fine. Or you could barrow rent or trade for a long bed truck but the extended hitch would be cheapest route.
Old Aug 31, 2012 | 11:43 PM
  #40
Deucedog's Avatar
Deucedog
When I had a Ram pickup, I could 'unhinge' the tailgate and let it hang down. That would take the weight off the tailgate while loading the bike.
