Reinstalling Strut Covers after TourPack Removal
Old Sep 1, 2012 | 03:38 PM
ZenGlide's Avatar
ZenGlide
Default Reinstalling Strut Covers after TourPack Removal
I need some guidance.
I just removed my TP and TP support bracket. When reinstalling the strut covers, I noticed the inside edge of the cover is now all the way against the fender. Without the bracket, the is nothing to "hold off" the space when tightening down the torx bolt. I can't see tightening the bolt as tight as it was with the support bracket in place because 1. I don't want the cover's edge digging into my fender paint and 2. I don't want to bend the cover by trying to close that space while tightening. Should I build up that space left by the missing bracket with washers before fully tightening?
Also, what is the best way to align the front saddlebag pin bracket when I reinstall it. I placed a piece of tape to align the bracket, but didn't realize it would also have some horizontal adjustment because of the slot in the bracket. Should I leave that bolt slightly loose and put the saddle bags back on to find the correct alignment before tightening it down in the correct position?
Thanks for the help.
Old Sep 1, 2012 | 03:41 PM
mkguitar's Avatar
mkguitar
I guess a couple of washers to space the struts out- you wanna make sure the extra length of the bolts isn't bottoming out on something.
put the bracket hand tight, put the bag on and check alignment, then tighten firmly.
take the bag off and tighten all the way, check fit and adjust if needed
Mike
Old Sep 1, 2012 | 08:22 PM
ZenGlide's Avatar
ZenGlide
Thanks!
Old Sep 1, 2012 | 08:42 PM
mkguitar's Avatar
mkguitar
BTW the pins may vibrate out on a rough road or if they spread over time and loose tension
if you are not confident about the pins, easily replaced with speed nuts & wingscrews
crown bolt part numbers 43228 and 66808 respectively and reuse or get new rubber washers.
That's about $9 in hardware at you local ace hardware or big box.
Mike
Hershey2487
Jan 11, 2015 09:06 AM
jots7
Feb 8, 2011 08:55 PM
live4rut
Sep 18, 2010 09:00 PM
doxbike
Sep 11, 2010 07:57 PM
strich
May 10, 2007 10:25 AM
