14" wild ones on SG wire question
Old Sep 2, 2012 | 11:06 PM
kustom78's Avatar
kustom78
Default 14" wild ones on SG wire question
hey all i know im gunna get flogged asking, but what will need to be done to the wires on my 12 SG to put these on? i know the cables and hoses need to be lengthened but the wires will probably need it to is there a wire kit i can but or if it cut and splice
Old Sep 3, 2012 | 08:55 AM
DuraGlide's Avatar
DuraGlide
12.5 is about the limit for not using extensions. Most extension kits are just a wire with male and female terminals crimped on. They use heatshrink to hold the factory male terminal in the add-on female terminal. Color coding makes them simple to match. Namz is the first company to come to mind.
Old Sep 3, 2012 | 09:01 AM
Northbound Southerner's Avatar
You will have to extend the wires. It is not that tough. If you run in to issues, PM me and I will give you my phone number...I just finished my second swap on my bike yesterday...Phat performance has an extension kit they sell. I used it for my first bar swap an it was fine. The second time, I had a pin break in the heat shrink and it gave me FITS trying to find...If it were me, I would get a cold beer, sit at the kitchen table and extend and soldier each wire instead of using the kit. It is tedious but it will be done right. If you don't know how to soldier, take a look at Youtube. Look up Flux soldiering...There is a video on there that my brother used and he learned some stuff the Air Force didn't teach me at Tech school...
Old Sep 4, 2012 | 11:02 PM
kustom78's Avatar
kustom78
i did it pulled the trigger on a set of 14" wild 1's, now my question is where should i get my extended cable and hose? i want stainless braided stuff and ide rather get a wire extention kit like the namz kit.
Old Sep 5, 2012 | 08:20 AM
I would get it all from phat performance. Thys have good prices and good customer service. I put magnum cables on mine and they are great. Stay away from the extension kits. I had up s break off and cause a mess. I would just soldier all the extensions so you know they will hold up...
Old Sep 5, 2012 | 08:22 AM
Clean's Avatar
Clean
Lots of work, but worth it when your done, buy wire extensions.
Old Sep 5, 2012 | 11:13 AM
TUCCI's Avatar
TUCCI
I got a spool of 18gauge wire and used it to splice the wiring. It doesn't need to be colored since the object is to cut the wire in two place thereby splicing the original end to the longer length. I started from the closest to the hand-grip and staggering the splicing so the splices don't lay on top of each other doing the same when you get down to the 'Pin'. Take your time and use shrink wrap. I added a foot and a half for future height changes which is common.
Old Sep 5, 2012 | 11:40 AM
Yep...that...avoid the extension kits. They are a weak point. A good soldier will never come apart...
Old Sep 5, 2012 | 12:02 PM
TUCCI's Avatar
TUCCI
Exactly.....good solder, shrink wrap everything and grease it real good during the pull and you'll be real proud of what you've accomplished.....the hardest part was getting the Molex connectors to release the pins but have since bought a Molex pins release tool off ebay.....I can see going 16's someday....apes rock!
Old Sep 5, 2012 | 01:31 PM
slammed05fatty's Avatar
slammed05fatty
i ordered eveything to install mine at same time at hdbikeparts.com, bars,wires,cable,brake line
Sethc1020
Apr 11, 2019 07:53 AM
DYNAM1C
May 7, 2013 07:26 PM
nazareth27
Mar 14, 2010 07:12 PM
medic2931
May 26, 2009 07:47 PM
el ricky
Apr 4, 2009 07:22 PM
