Polishing stock windshield
Old Sep 20, 2012 | 02:41 PM
mkguitar's Avatar
mkguitar
Originally Posted by vistavette
The bottom of a batwing windshield has a very specific pattern; not sure it would be that simple. A new shield from one of the major suppliers would be easier and they're not that expensive - they come in a lot of heights too.
takes about 10 minutes & Goldilocks gets exactly the height desired
the beauty of cutting the bottom edge is that the cut is hidden, so it doesn't have to be pretty.
the rider may also choose to cut the keyholes wider, which makes for easier swaps--- when I swap to a different height seat, I swap windscreens to match.
another windscreen may be used as a template or just use a compass to scribe a line
and the cost of a take off stock H-D Lexan windscreen is about $35--- and for that price you get a tough no shatter windscreen with great optics
mike
Old Sep 20, 2012 | 04:29 PM
Dale_K's Avatar
Dale_K
I've never had any luck polishing Lexan windshields. Like the other posters said, they have an anti-scratch coating. I took a windshield to a boat shop once and asked them to polish it and all they did was burn off part of the coating. I see a Clearview in your future. They're plexiglass and you can polish them successfully.
Old Sep 20, 2012 | 08:41 PM
RoadHog659's Avatar
RoadHog659
mike
Goldilocks? Maybe Gray-dilocks, but certainly not Goldilocks. Nobody's called me Goldilocks in 20 years, maybe 30. But you may have something with the "$35 take off" idea. The reason I wanted to polish out the scratch is because I actually like the stock shield better than the after-market ones I've had before. I think I'll spend some time over in the Classifieds to see if I can pick up a near-perfect H-D take-off shield.
Old Sep 20, 2012 | 09:11 PM
oneballz's Avatar
oneballz
YouTube has videos showing how to polish it out
Cee Baileys has a very reasonable price for you to send it to them & they'll make it look new again.
Old Sep 21, 2012 | 10:13 PM
roadhog96's Avatar
roadhog96
That's right, Harley windshields have a very thin protective film on them which is usually what scratches. Warning, if you try to polish the scratch out it will look worst once the film around the scratched area wears through from polishing. You would be better off not touching it. I removed all of the film on an old Harely windshield that had several scratches. I scraped it of with my thumb nails. It just flaked off, didn't scratch the windshield at all doing this and it looked like a new windshield once all the film was off. What appeared to be scratches were in the film only. Without the protective film over the lexan it will probably scratch.
Old Sep 22, 2012 | 05:57 PM
Lyfer's Avatar
Lyfer
Don't think Novus will work on stock. May even make it worse. It (Novus) works great on my Cee Bailey's though!
Old Sep 22, 2012 | 06:37 PM
jpooch00's Avatar
jpooch00
These windshields are made of Lexan (polycarbonate), which has a fairly soft core with a hard-coat on the outside. Any scratches that penetrate the hard coat are not repairable. Swirl-marks and very light blemishes like that can sometimes be buffed out though. Deep scratches on Plexiglas (acrylic) can be sanded and buffed out, but not Lexan.
Good luck
flipbel
Jan 4, 2014 10:39 AM
mrfikser
Aug 4, 2011 12:36 PM
Dalej
Aug 20, 2007 08:41 PM
bobam52
General Topics/Tech Tips
Feb 10, 2007 05:37 AM
mooks005
Sep 16, 2005 10:12 PM
